Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 02-13-2018, 05:03 AM
brown1's Avatar
brown1 brown1 is online now
Corporal
Member's Gallery
Default P054f normal in cold?
my truck has thrown a P054f “fuel quanity higher than expected at idol” code several times this winter particularly when very cold. could this be a tuning issue or something deeper? i have weight loss with race pipe and gh tunes through a x4.
__________________
GO BLUE!
  #2
Old 02-14-2018, 03:06 AM
ZCherry27's Avatar
ZCherry27 ZCherry27 is offline
Private
Member's Gallery
Default
Ohh I want in on this. I have the same setup as you. I've noticed it more in fresh snow/slushy roads and feels like truck tries power through brakes at stops.
__________________
03 CCSB 6.0 with the usual 6oh "maintenance" done 4inch BDS 20x12 Fuel Hostages 35x12.5 Nitto Trails SCT with custom tunes -Sold
14 CCSB 6.7 weight loss SCT with GH
  #3
Old 02-14-2018, 08:44 AM
dsmracing1's Avatar
dsmracing1 dsmracing1 is offline
Major
Member's Gallery
Default
I’ve had this code and my tuner told me to disregard it. I’ve only had it once however...
__________________
2014 F-350 Platinum CCSB 4x4
No Limit Fabrication/EZ-Lynk Proven Diesel Tuned/OUO/3.5 SST Ready Lift/Bilstein/Flo Pro/BDS/Midwest 65.5 StreetmaxR Turbo Kit, Piping & Dual Fueler, H&S LPFP
Dyno: 655/1240
"The Work Truck"
  #4
Old 02-14-2018, 10:26 AM
ZCherry27's Avatar
Private
Member's Gallery
Default
Mines only happened 2 or 3 times max so didn’t feel the need to start a thread until it became a more consistent issue or in this case seen a thread about it at top of forum
__________________
  #5
Old 02-20-2018, 06:45 AM
brown1's Avatar
Corporal
Member's Gallery
Default
nobody?
__________________
GO BLUE!
  #6
Old 02-20-2018, 02:37 PM
BuiltPowerStrokeTough's Avatar
BuiltPowerStrokeTough BuiltPowerStrokeTough is offline
Lieutenant
Member's Gallery
Default
Do you have a 13-14? Sounds like this code is specific to those years only and sounds like it may be an issue with the Ford software from this link I found. Possibly, if the tuner built the original file off of older Ford software on the 13-14, the issue could remain present in their d-elete files as well. You may have to try another custom tune from a different tuner if they are not willing to fix it for you. Just a theory though. Maybe someone else on here with tunes other than GH can chime in if they have had the issue as it seems like multiple people on here are running GH with the problem. Maybe check with Mike at No Limit and he could get you some different tunes to try or try to fix the ones you have. Heres the link I was referencing.
https://ford.oemdtc.com/993/mil-illu...d-f-super-duty
__________________
Nathan
2017 F350 6.7 PSD XLT, Bronze Fire Metallic CCSB
  #7
Old 02-21-2018, 09:37 PM
2014f350 2014f350 is offline
Private
Member's Gallery
New here, first post... Created an account just for this.
I've been having this issue to, I'm in Northern Alberta and we've regularly seen temp drops to -28C in the last few weeks and a few times in the last few months.
I'm tuned with a Bully Dog and I kept getting this code it ultra low Temps, it would seem to pop on while I was idling at lights. The bully dog has an engine warm up mode that doesn't kick in til 75C. It also goes back into warm up mode below 75C.
I noticed one day at a red that the P054f kicked in at the same time as the engine warm up mode turned back on. I've probably cleared that code a half dozen times before this but had never seen it kick on before, I actually saw the CEL light come on this time. So it got me thinking that as the code means too much fuel maybe it had something to do with the tune kicking out at a certain temp.
I shut off the engine warm up mode last week and haven't seen the code since. It was -27C here today too.
Sorry about the metric, I'm Canadian eh!
Hope this info helps, I'll report back if I see the code again.
Sent from my iPhone using Tapatalk Pro
__________________
2014 F350
4" Levelling kit
35" Dura's
******d, Bullydog tuned, 5" Pipe
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
