Go Back   PowerStrokeArmy > Power Strokes > 6.0 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 06-01-2017, 01:31 PM
Extended Power's Avatar
Extended Power Extended Power is offline
Major
Member's Gallery
Default Finally broke down and took truck in...
I haven't driven my truck since last spring.
After I put the 330/150 injectors in, along with the 6-phase FICM, and ficm tuner...the truck was taken out for a test rip.
Bounced off the rev limiter through 3 gears in two wheel drive, (should have known better than to leave it in 2wd when fartin around.) and when I came to the stop sign, the truck had a definite "miss", as the truck was shaking at an idle.
So I had Eric send tunes for these injectors, Jesse, and someone else who's name I can't remember right now.
None of them shift correctly...they all seem to get to about 2000rpm, and lockup in each gear. No downshifting unless you come to a complete stop.
No power...just smoke.
So today, after waiting a little over a year to find the time to work on the engine, I took it to a shop to do a couple tests. Compression, and injector testing.
The whole year was spent working on the interior, and stereo system...and I didn't want to start ripping into the engine, with sawdust all over everything.
I tell ya...I'm to the point where I'm tired of working on it.
I honestly thought after I'm done the stereo, the truck was done...only other thing was going to be a new paint job...but at least I could drive it, and not have to wrench on it anymore.
The the test drive happened, and it pretty much pulled the carpet out from under me.
Hope they find something easy.
If it's an injector, they will be for sale.
Cost was over $3200.00 with new solenoids, and spool valves.
I want my 285/100 conventionals back. Lol
__________________
2003 F350 King Ranch ccsb 4x4
793hp fuel only
12.2 @ 113.06mph
  #2
Old 06-01-2017, 02:05 PM
thewrubelator's Avatar
thewrubelator thewrubelator is offline
Lieutenant
Member's Gallery
Default
damn, bummer!! Should be a quick diagnosis if the shop has IDS.
__________________
2004 F250 RCLB
Warren Diesel - RCD - Wagler - No Limit - ID - DNR Customs - Flight Fab
  #3
Old 06-01-2017, 02:08 PM
Lieutenant
Member's Gallery
Default
I've been to that point, seems to be more work than enjoyment. But when it works...it makes it oh so worth it lol
__________________
2004 F250 RCLB
  #4
Old 06-01-2017, 03:57 PM
Major
Member's Gallery
Default
Yeah, I know...I remember those days.
But right now....not so much.
Both times I have tried a 150% nozzle, I hated them...too much smoke for me.
It's impossible to find a tuner anywheres close to me to do any "Live" tuning...and I can't drive 24hours to have it done...the smog tickets alone would probably pay for airline tickets to fly a tuner up to Canada.
__________________
793hp fuel only
12.2 @ 113.06mph
  #5
Old 06-01-2017, 07:36 PM
06f250powerstroke's Avatar
06f250powerstroke 06f250powerstroke is offline
Lieutenant
Member's Gallery
Default
What turbos are you running also are those 8mm hybrids?
__________________
340/150 crew cab sb
63/80 compounds
4 link
11.7 @118
871Hp fuel only
967 hp nitrous
  #6
Old 06-01-2017, 07:39 PM
Major
Member's Gallery
Default
Well....no call from the shop today.
I asked for it to be parked inside if it had to sleep over.
And tonight, we are getting crappy rain, wind, lightning, and still possible hail...
Hope they say it's down on compression on two cylinders, and has two or three bad injectors...cuz that's what it's performing like...and at least I will know I can start to tear it down. Have a new DFC 0.020" over block, DPC converter, and Straub cam to slide in.
.....nuff messin round...
__________________
793hp fuel only
12.2 @ 113.06mph
  #7
Major
Member's Gallery
Default
Quote:
Garrett, gt55, 94mm feeding a Borg 69mmSXE.
Yes, 8mm hybrids.
__________________
793hp fuel only
12.2 @ 113.06mph
  #8
Old 06-02-2017, 10:29 AM
Major
Member's Gallery
Default
Call came in from the shop this morning.
Injectors #5 & #7 are dead.
Compression is down on cylinder #5 as well....325 lbs.
But #5 is the hole that I had an injector tip break off about 4 or 5 years ago.
Anyone know what "good" compression should be?
__________________
793hp fuel only
12.2 @ 113.06mph
  #9
Old 06-02-2017, 10:33 AM
samgoto96 samgoto96 is offline
Private
Member's Gallery
Default
400ish psi
Sent from my XT1650 using Tapatalk
__________________
2000 F350, BTS Trans, BTS twin HPOP, FF 300/200s, FASS fuel, Fire ringed, Irate T4 system with his 468 Turbo, Swamps IDM, and all the mods that go with :-)
  #10
Old 06-02-2017, 10:35 AM
Major
Member's Gallery
Default
I will be pulling these injectors out at some point soon...
Deciding on what to do....swap out the 150 nozzles to 100's, or go back to conventionals.
__________________
793hp fuel only
12.2 @ 113.06mph
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
