** Core pumps/injectors/pcm/ all brands **
AirFishAutomotive
DELAWARE
Here is a list of what all we buy for those of you who work on a little bit of everything
***Injection Pumps- No Broken Plugs Accepted***
-Bosch P8500 0-402-996-xxx
-Cummins AFC VS Dual Spring (Black oval cover on AFC)
Cummins AFC VS Pump
Cummins CAPS
Cummins MINI CAPS II
Cummins CP3 0-445-020-011/015/039/072/076/106/107/143/148
Cummins P3000
Cummins VP30
Cummins VP44
Cummins 5.9L VE (0-460-426-103/114/184/025)
Cummins P7100 (0-402-736-838/841/854/885/887/911/912/913)
Ford 6.0 Pump (03-07)
Ford 7.3 Pump (Must have both fittings)
Ford 7.3 STANADYNE Pump (Must Turn and Click)
GM DURAMAX 6.6 CP3 (0-445-020-005/017/030/037/039/105)
John Deere STANADYNE DE Pump
Navistar DT 466/DT530/I530 (Must have supply pump)
***Fuel Injectors***
CAT C7/C9
Cummins 8.3L Common Rail
Cummins ISX (must have link on top)
Cummins ISX15
Cummins M11&N14 Celect
Cummins Pegasus
Detroit 4 Pin N3
Detroit 4.2 CRIN
Detroit Series 60 (Part #5000 or up, must be complete)
Cummins 6.7 Common Rail (part number depending)
Duramax 6.6 LB7 2001-2004 (0-445120-008)
Duramax 6.6 Late Model 2004-2010 (0-445-120-027/042/082)
Navistar G2.9 DT466/DT570/MAXXFORCE
***Turbochargers (Must Spin, Wheels intact, No damaged/cracked housings)***
CAT 3406E
CAT ACERT C13/C15 High Pressure and Low Pressure
Cummins HE351ve
Cummins ISX Holset He431ve
Cummins ISX Holset He451ve
Cummins ISX Holset He551v Must have mechanical actuator
Cummins ISX Holset He551ve Must Have Electric Actuator
Cummins ISX Holset He561ve Must have electric actuator
Duramax 6.6
Navistar S300V
Any non van 7.3/6.0 pcm can be bad etc
Pm us or call 302-875-2818.
You are paid same day as parts arrive !
Moto9673
phoenix arizona
Air fish do you re sell them once you get them. Im been looking for months for a PMT1, PMT2, Or a NvK4 pcm for my truck with no luck.
Nick7.3
Any interest in a good 6.0 cam?
