2011+ Rear Diff Questions
WhiteMamba_Scorpion
I'm trying to put together a parts list to rebuild my 2012 F350 SRW rear diff with a TrueTrac and Rebuild kit that has Timken Bearings. Some sources say the 2011+ has a 35 spline 10.5" rear end and others say its a 31 spline 10.5? I have no clue which is correct. So can anyone verify for me 100% WTH is in my rear end.
I've attached the parts from Summit I was certain would fit but I'm really 2nd guessing myself. I verified the G2 rebuild kit does use Timken bearings but it says its for a 31 spline 10.5 while the TrueTrac says 35 spline? Any word of advice would be great.
Betarocker
Sea to Sky, BC
I can't answer your question, but you can park on a slope and remove the axle shaft without leaking diff fluid and count the splines and measure the diameter.
Zmann
that spline count discrepancy has been around for a long time
8WR_ZJ
For the Ford 10.5", 2011 & Newer. This differential has a 37 spline pinion as opposed to the 31 spline pinion found in earlier model 10.5" diffs. I am pretty sure they are all 35 spline carriers though. Now axle length has changed but other than that I am not aware of any of this. I have rebuilt thousands of axles and swapped parts back and forth.
WhiteMamba_Scorpion
So basically the Pinion count doesn't matter whether its a 37 spline pinion 2011+ or an earlier 31 spline pinion when you buy a rebuild kit as long as the spline count on the carrier is correct?
So will that G2 Part #35-2046A (Which G2 says is for Ford 10.5s) will work on a 2011+ 37 spline pinion even though it says the kit is for a 31 spline pinion since both share a 35 spline carrier?
8WR_ZJ
I will have to look at my setup b3arings and make sure the numbers are the same. Idk if i have sets of gears for both axles right now.
8WR_ZJ
Pinion count will only matter if you are ordering a new gear set. All carriers are the same spline count for the 10.5 and 10.25 rear axles. I have put a 1995 10.25 carrier in a 2007 rear end I just had to get 10.5 carrier bearings to do this.
Yes from looking at my setup bearings I do not have a split for 31/37 spline pinions. So that means the bearings are the same and only the rear pinion seal is different. I have a note written in my setup box and part numbers written down for the pinion seals. I am very picky about setup bearing sets.
WhiteMamba_Scorpion
10-4 Thank you sir.
gonna revive this one..
what all did you end up getting parts wise and for the trutrac? specific numbers?
WhiteMamba_Scorpion
TrueTrac
Overhaul kit
Ring and pinion
Drives absolutely amazing!!! I love it!
TrueTrac
Overhaul kit
Ring and pinion
very nice! completely rebuilt and regeard diff for less then 1500 bucks in parts.. that ain't bad at all man!!!
I have a trutrac in my dually.. I love it.. I want one in the 6.7 now. wanted it since the day I drove it off the lot..
WhiteMamba_Scorpion
I actually already had 3.73s but I ended up getting new Yukon Gears while I was at it because the oem R&P were starting to wear uneven. But yes if I knew these drove this awesome I would of had one WAY sooner. Now I see why everyone recommended the TrueTrac. Im definitely very pleased with the results. I also used LE1605 from Jim for the rear diff oil too.
m j
BC Canada Eh!
is the 10.5 different then the 10.25 for setup? I am trying to figure out why someone would need setup bearings on an axle that places the shims outside the bearings
right on!
what was his reasoning on using 1605?
WhiteMamba_Scorpion
right on!
It doesn't have any friction modifier in it since Eaton was very specific about making sure you don't use a friction additive when using the TrueTrac.
