Go Back   PowerStrokeArmy > Power Strokes > Excursions
Reply
Thread Tools Display Modes
  #331
Old 04-23-2017, 05:07 PM
heavydoc's Avatar
heavydoc heavydoc is offline
Lieutenant
Member's Gallery
Default
It is a really nice looking X. I might have to redo mine now.
Sent from my SM-N920V using Tapatalk
__________________
1996 F350 2WD PSD RCLB dually, 6637 air filter and 17 position hydra, quad guages. 05 axle swap soon.
2001 Excursion Limited PSD 4X4, 6637 air filter.
2002 F350 Lariat 4WD PSD CCLB dually, 6637 air filter, and international bellowed uppipes.
  #332
Old 04-23-2017, 05:09 PM
01_Excursion's Avatar
01_Excursion 01_Excursion is offline
Private
Member's Gallery
Default
Quote:
Originally Posted by lincolnlocker View Post
holy chit!! that is an absolute beauty of a ex!! well done sir!!
Thank You. I'm pretty proud of it so far. So much has been done in the last year that you just don't see, or knew was replaced. Corrected/correcting the screwed lift, replaced the crap tires, upgraded water pump, batteries, high amp alternator, upgraded starter, many interior trims, all the weather strips are new, replaced the ford accessory nerf bars with the same as they were starting to corrode through, LED lights above the step pads, new turn signal lever, shift lever, headlight switch, upgraded to the signal mirror option of that year, ford parts only, I already had tow with heat. I sourced a set of Limited trim Medium Graphite door panels, rare but they're out there, which gave me the factory wood grain trim.
Next up is a package to Dallas Custom Steering wheels. My current wheel is all the same grey, the circumference is going to become the same blue leather, not sure if I want the whole ring in blue, or the top and bottom in blue, and the sides in the same grey. I'm leaning towards the two tone I think. I had thought I wanted matching blue carpet, knowing I'd have to see the truck after the seats were done, I decided no blue carpet, and the original grey was just fine. After the steering wheel is done, the last possible addition of blue might be the lower door panel carpets.
  #333
Old 04-24-2017, 09:23 AM
Wayne's Avatar
Wayne Wayne is offline
Major
Member's Gallery
Default
What type of floor mats do you have in it? I haven't found much for the rear of the x, but I haven't looked in a while either. I run husky liner weather beaters up front, but the kids make quite a mess in the back with crayons & crackers.
  #334
Old 04-24-2017, 09:59 AM
dsberman94's Avatar
dsberman94 dsberman94 is offline
General
Member's Gallery
Default
Shouldn't superduty mats fit the second row?
__________________
02 F250 7.3 Crew Cab Short Bed Lariat
PHP Hydra, Ge4rhead tunes, Edge insight CTS monitor
Mild Trans Build, Dual disc TC
GTP38R, T500, PIS 175/80s in the engine. waiting to see rods one day
Turned 200k miles 1/18/2015
  #335
Old 04-24-2017, 04:36 PM
Private
Member's Gallery
Default
Quote:
I went with a full set of Weathertech mats, the laser measured, 3D in the front, standard set for the middle (front & back of 60/40 bench), and full mat for the rear. The full rear mat gives you coverage up to the drop off just ahead of the 3rd removable bench. The non full rear mat stops at the release handle of the 3rd bench.
http://www.weathertech.com/ford/2004...er-digitalfit/
http://www.weathertech.com/ford/2001...n/cargo-liner/
  #336
Old 04-25-2017, 10:20 AM
Wayne's Avatar
Major
Member's Gallery
Default
thanks. I'm a big fan of the laser fit mats. Not too much of a fan of the original husky liners though. I'll be ordering that rear mat when I get my interior done.
  #337
Old 04-25-2017, 05:54 PM
Private
Member's Gallery
Default
I actually chose the wrong color leather from the ford book, between the book and my original seats, it appeared I should have Light Graphite, my color code is Medium Graphite. I had to re-order the vinyl and leather in the darker grey.
So I have enough hides and vinyl in Light Graphite to do an Excursion, that I need to sell at cost.
  #338
Old 04-26-2017, 10:04 AM
Wayne's Avatar
Major
Member's Gallery
Default
Thanks for the heads up, but I'm going with black interior when I get around to it. I built it off of an '08 XLT, and really want the lariat features. I just got a line on an '09 lariat interior with all the necessary components to convert, but it's a month or so out. Once I get my hands on it, I'll be finishing it up. I just went with black katzkins with the gator inserts for upholstery.
  #339
Old 12-17-2017, 10:36 PM
Excursion24x16's Avatar
Excursion24x16 Excursion24x16 is offline
Private
Member's Gallery
Default
  #340
Old 12-18-2017, 02:53 AM
heavydoc's Avatar
Lieutenant
Member's Gallery
Default
Quote:
Originally Posted by Excursion24x16 View Post
Pic no worky
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
