Go Back   PowerStrokeArmy > Power Strokes > 6.0 Tech
Reply
Thread Tools Display Modes
  #11
Old 04-14-2018, 06:40 AM
Corys6.0 Corys6.0 is offline
Sergeant
Member's Gallery
Default
Quote:
Originally Posted by Decker View Post
Should of cleaned the system out before putting in new cooler. Not just a coolant filter but actually flushing out the system.
A big name shop did it all I figured they would have done that. Iím gonna call them. They said there is a 2 year warranty on the oil cooler IIRC.
  #12
Old 05-12-2018, 06:59 AM
junglejoe's Avatar
junglejoe junglejoe is offline
Sergeant
Member's Gallery
Default
For what its worth.. I have went through 5,yes 5 oil coolers after the Egr and oil cooler ruptured! I even used DC9 and at least 60 gallons of water to flush!!
__________________
06 CC Long bed FX4---- 11 inch 4 link RC lift w/dual front shocks 37 inch Trail grapplers w/ dual steering stabilizer's
SCT Live Wire w/ I n n o v a t I v e Diesel Tunes
S&B air Intake
5 inch exhaust w/muff and cat gone
RCD 155/30 injectors w/ regulated fuel return
Stock turbo(32lbs of boost)
  #13
Old 05-12-2018, 09:52 AM
79jasper's Avatar
79jasper 79jasper is offline
Colonel
Member's Gallery
Default
Quote:
Sounds like the ipr full flow coolant filter (or similar) could have done you some good. Lol
Sent from my SM-G892A using Tapatalk
__________________
2003 F250 KR SCSB FX4
Depleted, studded, airdog (which isn't currently hooked up), fass regulated return, airaide, 4 inch straight pipe with mbrp muffler(so on to go), glowchit pyro, fuel, boost, and trans temp. (Of course don't work lol) Hercules terra track A/T2 315/70/17.
2013 Honda pilot Touring
http://badges.fuelly.com/images/sig-us/778639.png
http://badges.fuelly.com/images/sig-us/776628.png
  #14
Old 05-13-2018, 03:05 PM
Sergeant
Member's Gallery
Default
So is this a thing? Change oil cooler every 8-10k miles? I did a coolant filter when I did the bulletproofing. I can’t afford to change oil coolers every 8-10k miles. Remote oil coolers are big money. I’m not sure what to do. I already have tons of money in this truck. Runs amazing. Sounds amazing and is clean but it’s my daily and toes my race car so it needs to stay healthy. Oil coolers plugging every 6 months isn’t good.
  #15
Old 05-13-2018, 06:12 PM
79jasper's Avatar
Colonel
Member's Gallery
Default
Right, but you have a bypass coolant filter. Which doesn't actually do much. The full flow one literally goes online to the oil cooler and will stop anything and everything.
__________________
  #16
Old 05-13-2018, 08:06 PM
Sergeant
Member's Gallery
Default
Ahh ok, is that what most are doing? You have a link of the one you speak of?
  #17
Old 05-13-2018, 08:30 PM
79jasper's Avatar
Colonel
Member's Gallery
Default
I don't think I've seen another brand.
https://www.iprresearch.com/IPR-High...F350-F450.html
Supposedly if you flush it well enough, it's not an issue.
__________________
  #18
Old 05-13-2018, 08:50 PM
bismic bismic is offline
Sergeant
Member's Gallery
Default
There are quite a few posts about back flushing w/ hose water and compressed air (to provide agitation) as being the most effective way of getting rid of heavy contamination.
__________________
Lots of good stuff
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
