Go Back   PowerStrokeArmy > The Bunker > General Discussion Forum
Reply
Thread Tools Display Modes
  #30001
Old 05-10-2019, 08:50 PM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
I’m trying to produce milk Jake......
I like chopping alfalfa
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, S471, Beans IDM, ARP head & main, girdle, half filled block, DI cam, Dual IPRs, ceramic coated bowls, anti-friction skirts, Haldex pump over Stock pump, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #30002
Old 05-10-2019, 08:56 PM
ja_cain's Avatar
ja_cain ja_cain is offline
Colonel
Member's Gallery
Default
Quote:
Originally Posted by Magnum PD View Post
Iím trying to produce milk Jake......
You can just load that on my trailer sir. I'll head on up tomorrow. Lol!
Sent from my Pixel 2 XL using Tapatalk
  #30003
Old 05-10-2019, 08:58 PM
Magnum PD's Avatar
General
Member's Gallery
Default
We do have some nice 1st cutting coming up
__________________
  #30004
Old 05-11-2019, 09:11 AM
threegenpowerstroke98 threegenpowerstroke98 is offline
Sergeant
Member's Gallery
Default
Quote:
Originally Posted by ja_cain View Post
You hit the nail on the head. No reason to throw more protein than needed at an animal. I would rather have high sugar/carbohydrate hay to feed those rumin bacteria. The natrual die off of the bacteria will supply some protein also. Thanks for posting those numbers. That 3rd trimester is killer as the lamb/fetus is growing at an exponential rate. What kind of sheep did you keep?
My base herd was corridale rambouillet crosses. I then started breeding them to straight suffolk. My business was grass fed lamb, was selling them off the rail back in high school. When feeding a high energy diet, I'm assuming you're mixing in a fair bit of a fibre source if you're pushing the sugars?
__________________
01 ccsb lariat, custom straight pipes, php tunes, edge cts II dead but not forgotten
11 ecsb xlt, 325/60r20s, 20x10 pro-comp rims, mpd budget t4, sxe 364.5, H&S intercooler pipes, G3arhead tuning, five inch flo-pro to 6 inch tip, minimaxx, 514rwhp, 908 ib/t torque on bald tires
  #30005
Old 05-12-2019, 02:14 PM
ja_cain's Avatar
Colonel
Member's Gallery
Default
Those are beautiful looking larger frame wool breeds. I would love to cross some of my katahdins with a Suffolk. Just not a real good idea in the south unless I can keep close tabs on them by famacha scoring them on a regular basis. Don't have a chute and time to do that right now. Not to mention I would probably still need to shear them.
The sugar thing is relatively speaking when desciding between time of day to cut, 3rd vs 1st cutting and stage of growth. Definitely not a good idea to switch straight over to high sugar/carbohydrate hay, just like it isn't good to give 2 lbs of grain right away to a lactating ewe. Need to give the rumen time to adjust. I've got a few cool articles kicking around that illustrate all of this. Will share them once I have a chance. You are correct though, the rumen needs a significant amount of fiber to keep it working correctly. That's why they always suggest planting something like rye grass with brassicas when being used in a grazing scenario.
  #30006
Old 05-12-2019, 08:04 PM
Magnum PD's Avatar
General
Member's Gallery
Default
Is there suppose to be a seal here??
On my front Dana 60
__________________
  #30007
Old 05-12-2019, 08:06 PM
Magnum PD's Avatar
General
Member's Gallery
Default
What is number #90?
https://www.dennysdriveshaft.com/c72...or_BRAKE_ROTOR
__________________
  #30008
Old 05-12-2019, 08:17 PM
psduser1's Avatar
psduser1 psduser1 is offline
Colonel
Member's Gallery
Default
On my front Dana 60
It's a "dust seal", technically. I think, new, they worked pretty well, maybe, but as the joints, ball joints, hubs wear out, the seals tend to get beat up pretty badly.
They aren't terribly expensive, doesn't hurt to replace them.
In the '80s, Dana never used them on any front axle.
__________________
2000 f250 zf6, air, oil, fuel mods, flatbed dual dana 80
Almost stock
2001 f250 same setup as the 2000, auto trans
2002 with a couple of mods, grocerygetter
  #30009
Old 05-12-2019, 08:23 PM
Magnum PD's Avatar
General
Member's Gallery
Default
I’ll see if NAPA has them
__________________
  #30010
Old 05-13-2019, 05:05 PM
ja_cain's Avatar
Colonel
Member's Gallery
Default
I love this guys articles. He's got it going on. I also follow him on FB and hope to one day internship at his place.
http://smallfarms.cornell.edu/2018/0...s-fed-sheep-2/
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
