Go Back   PowerStrokeArmy > Power Strokes > 94-97 Aftermarket
Reply
Thread Tools Display Modes
  #61
Old 05-04-2019, 03:47 PM
Peroni's Avatar
Peroni Peroni is offline
Sergeant
Member's Gallery
Default
Quote:
Originally Posted by gnxtc2 View Post
Looks good.
What's that billet looking idler pulley?
Also, what hydroboost unit are you using?
Billy T.
gnxtc2@aol.com
Pulley is part of my electric vacuum pump conversion, look for my other thread for more info on it.
Booster is MC# BRB-37
__________________
97 Green F-350 XLT 7.3L PSD 4x4 CC LB BTS E40D Manual Hubs 4.10 36000 miles when purchased 4/1/06. Mods - ISSPRO Performax gauges, Tymar intake, Tymar 3x4 DP to 4" ss exhaust, custom rear disc brakes, hydroboost conversion w/ 6.0 p/s pump, electric fuel, MANN CCV filter,LPF9750 oil bypass, 6.0 fan, tru-cool 4739, Swamps 200/30 injectors, Adrenaline HPOP, BASB turbo, Fluidampr, Spearco 6.0 cac.
05 Silver Mk4 Jetta GLS TDI
  #62
Old 05-04-2019, 05:33 PM
gnxtc2's Avatar
gnxtc2 gnxtc2 is offline
Major
Member's Gallery
Default
Would you know the thread size to convert the fittings on the P/S pump and booster to JIC/AN? Or the part numbers for the fittings.
Thanks
Billy T.
gnxtc2@aol.com
__________________
'97 Black F250HD SC, 3.55s, Punisher Trans, PI Converter, Dana 60 RSK w/ V & C SD springs, PIS 175/80s, T500, Cale's tunes, 910s, Smith Bros, ARPs, Fluidampr, IC, E-Fuel, 3" Plenums, CJC Traction blocks, HFHV IDM, T4/BASB, Horton, 268K
- 2016 F350 DRW Ultimate (stock for now )
- 1987 Buick Grand National (Staged)
- 2004 Mercury Marauder
- 1993 Geo Prizm (beater)
  #63
Old 05-05-2019, 07:15 AM
Peroni's Avatar
Sergeant
Member's Gallery
Default
Thanks
Billy T.
gnxtc2@aol.com
I know the pump fitting is M16x1.5 as I made my own. Not sure on the booster, I kept the stock lines on mine. Pretty sure Lee Power Steering can hook you up with the correct fittings if you give them a call.
__________________
  #64
Old 09-28-2019, 10:32 PM
Lt.Dan's Avatar
Lt.Dan Lt.Dan is offline
Sergeant
Member's Gallery
Default
Rock Auto sells them also under AC Delco part# 36P1613.
Billy T.
gnxtc2@aol.com
I'm bringing this back up right here. On rock auto, under 2000 E350 Vans, they have several pumps that include pulleys.
Anybody know if they are correct pulleys? Some of these pumps are only $40...
If they are correct, I'm gonna snatch one up and put it away for future use...
__________________
"Shamu" 1996 Cali F350 DRW CCFB, 7.3/E4OD, 2wd SAS w/ 392,000 miles, rebuilt at 352,250.
"Moby" 2018 F350 DRW, 6.7/6R140, 4wd w/ 34k miles
  #65
Old 10-04-2019, 01:30 PM
Lt.Dan's Avatar
Sergeant
Member's Gallery
Default
Nobody?
__________________
  #66
Old 10-04-2019, 02:32 PM
gnxtc2's Avatar
Major
Member's Gallery
Default
Buy it and let us know. You can always return it.
Billy T.
gnxtc2@aol.com
__________________
  #67
Old 10-05-2019, 08:59 AM
Lt.Dan's Avatar
Sergeant
Member's Gallery
Default
How do I know if it's correct? Is it the offset of the pulley being incorrect? Or the shaft diameter? If it comes with the pulley I'm assuming it's the correct shaft diameter, because the pulley is already on it.
What is the correct offset?
__________________
  #68
Old 12-19-2019, 01:35 PM
g_wall7.3 g_wall7.3 is offline
Private
Member's Gallery
Default Ps Pump Pulley
Did you ever order one of those pumps from rockauto to try out?
  #69
Old 12-20-2019, 10:49 PM
Lt.Dan's Avatar
Sergeant
Member's Gallery
Default
Quote:
I did not, havent had the time or money for the other parts. Too many other projects lol
__________________
  #70
Old 02-27-2020, 06:31 PM
Tylerjehowski Tylerjehowski is offline
Private
Member's Gallery
Default
I have a full setup for sale if anyone is interested? Bracket, pump with pulley, vacuum pump and reservoir.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Designed by Military Ltd
