Go Back   PowerStrokeArmy > Premium Vendors > Elite Lubrication Specialties
Reply
Thread Tools Display Modes
  #1
Old 03-11-2015, 10:53 AM
jimdawg185's Avatar
jimdawg185 jimdawg185 is offline
Major
Member's Gallery
Default The Baddest Bypass Filtration You Can Imagine
I am working on a bypass filtration that will make the others on the market look like child's play.
It would hold more than 5 gallons of oil, run completely separate from the engine itself, and could even have an extra cooler on it that also runs separate from the OEM. It also uses a 3<um Beta 1000 filter on it that holds 10 pounds of dirt and a gallon of water. This obviously isn't for your 10k a year DD, but for those that haul and want to really extend oil changes and keep oil temps where ever they want them.
It will be a true kidney loop that runs either when you wish or set to run on all the time, or at certain engine temps. Whatever, the sky is the limit.
So, what do ya'll think....
Oh, did I mention it wouldn't cost much more than the others on the market.....
__________________
The LE Promise:
No other brand of petroleum lubricating
oil whatsoever, regardless of price, will
be found superior in condition to
Lubrication Engineers products at the
end of any given period of use.
CLS Certified STLE
MLT-1, MLT-2, MLA-1, MLA-2 Certified ICML
ISO 9001
J.KUKULSKI@le-inc.com
616-460-9949
  #2
Old 03-11-2015, 11:09 AM
SEABEE08FX4's Avatar
SEABEE08FX4 SEABEE08FX4 is offline
General
Member's Gallery
Default
Sounds big, where would it mount ?
__________________
08 F-250 HTT S468, MPD Turbo Mounting Kit & Up-Pipes, AFE Intercooler, Ported Intake Manifold, 5" Polished Air Intake, FASS 220, FASS Sump, DIY Fuel Bowl D-elete, No Limit EGR Kit, 5" MBRP Turbo Back Exhaust, PTP Shift Solenoid, BD Diesel Manifolds, ARP's, Elite Valve Springs, Empire Pushrods, BD Tapshifter, Mishimoto Rad, BPD Remote Mount Oil Cooler Plates & Oil Filter Head, ICON 2.5 Stage I, Gear Alloy Big Block 22x12, Nitto 355/40/22 Trail Grappler MT's
  #3
Old 03-11-2015, 11:18 AM
psduser1's Avatar
psduser1 psduser1 is offline
Colonel
Member's Gallery
Default
Details man. Which platform (s)?
__________________
2000 f250 zf6, air, oil, fuel mods, flatbed dual dana 80
Almost stock
2001 f250 same setup as the 2000, auto trans
2002 with a couple of mods, grocerygetter
  #4
Old 03-11-2015, 11:55 AM
jimdawg185's Avatar
Major
Member's Gallery
Default
It should be basically universal to all diesel trucks with a spot big enough to mount it. Mine is going in the bed. It could be frame mounted as well, but that would be problematic in a few different ways.
__________________
The LE Promise:
CLS Certified STLE
ISO 9001
616-460-9949
  #5
Old 03-11-2015, 12:09 PM
ncollins64's Avatar
ncollins64 ncollins64 is offline
Colonel
Member's Gallery
Default
Interesting.
__________________
•2013 F350 CCSB PLATINUM
•08 F-350 CCSB 950/1493
Midwest Diesel, Elite Diesel, RCD, OUO, No Limit Fab, PMF Fab
•1997 F-350 7.3, srw, rclb, 4wd, 5speed (work truck)
•Past rig: 2000 F-350 ccsb, 1100 hp 6.7 cummins
  #6
Old 03-11-2015, 01:05 PM
Vader's Fury's Avatar
Vader's Fury Vader's Fury is offline
Colonel
Member's Gallery
Default
Interested in this. Sounds like it would be a great addition to my 450.
__________________
Robert
2003 F-350 CCLB, Frame off restoration in progress
2002 F-250 ECLB, Parts hauler
2002 Excursion, Twin hauler
  #7
Old 03-11-2015, 01:37 PM
jimdawg185's Avatar
Major
Member's Gallery
Default
I am thinking a 2.5 gallon unit will be an option as well. I am testing it out now on my truck as well as at the engineering department at WMU and this summer at GVSU since I am now a teacher at one program and a student at the other....
__________________
The LE Promise:
CLS Certified STLE
ISO 9001
616-460-9949
  #8
Old 03-11-2015, 02:47 PM
jimdawg185's Avatar
Major
Member's Gallery
Default
What I need from you guys is what would benefit you in you real day to day use of your trucks. I operate from a reliability engineers perspective. So I am basically using the principles that I use every day on power plant turbines and 10,000 gallon hydraulic units to our trucks. Over kill isn't bad, but I want as much feedback from those that have used these before.
__________________
The LE Promise:
CLS Certified STLE
ISO 9001
616-460-9949
  #9
Old 03-11-2015, 03:23 PM
powerstroked08's Avatar
powerstroked08 powerstroked08 is offline
Colonel
Member's Gallery
Default
If you could make a kit/filter that would mount on the frame rail I know i would buy one. Something that had a relatively long filter life would be a big plus.
__________________
2008 F-350 cclb ZF-6 speed
Just another white truck
Quote:
Originally Posted by Meniacal_Mark View Post
Time to dynamat the babies room lol
Quote:
Originally Posted by B585Ford View Post
Thats obviously for safety....ya never know when you might be going through an intersection and some idiot runs a light...anything under 1000HP and your toast.
  #10
Old 03-11-2015, 05:14 PM
NY_Mott's Avatar
NY_Mott NY_Mott is offline
Major
Member's Gallery
Default
Sub'd
__________________
Jay_Mott
First
08KR-CCSB
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
