josh@thedieselcartel
We now have in stock Factory Replacement Rigid Industries Fog Light kits for all Super Duty 99-15.
99-15 Trucks with Factory Fogs.
We have a 100% bolt on, plug and play kit available for your truck. These kits can use any of the D or D2 series lights. These kits come with all hardware needed to bolt these amazing lights in place of your factory lights. This will also include a custom wiring harness adapter that will allow the Rigid light to plug directly into your factory fog light plug. There is no wiring, splicing or headaches with this kit. Bolt on and go.
D Series Kits $285
D2 Series Kits $450
We also have kits for the 11-15 trucks with factory fog lights that will allow you to bolt on the new massive Rigid Q Series lights. These lights are equivalent to 4, yes 4 Rigid D series lights. These lights are massive, include bolt on bracket kit and plug and play wiring harness.
These kits start at $1050.
We can build you the lighting package of your dreams including LED Replacement headlight bulbs, full custom headlight build including custom paint, projector retrofit, halos etc, and any Rigid industries or other LED lighting brands.
Here is an example of the Q Series lights.
D Series Kits $285
D2 Series Kits $450
