2011-2014 Turbo Kits master list
Stangr8cr
So I just removed my turbo, still waiting on my 15 kit to get here. Are the stock up pipes reused or are they different from the 11-14 up pipes? Looks like in the pics that the upper up pipe is new but in Elites description of their kit, it only says down pipe is included. I tried calling Elite but they're gone for the day. Figured someone that has done it can answer before I take mine off. And as a side note for anyone contemplating this upgrade, the turbo comes out super easy. I had everything removed minus the driver side up pipe in 2 hours.
Keith
RedRice589
Ocala, Florida
Keith
Up pipes are replaced, down pipe is replaced as well. Here is a pic of mine. I believe one manifold and both up pipes are replaced, feed lines, pedestal, and yea idk the names of others.
Disregard all the background crap and the dog LOL
50_shooter
Central IL
What is the main advantages of the precision turbos? Is anyone running a precision on a 6.7 dd street truck? I am in the market for a kit. I want the best, but have no clue which one that is. I want to tow 14k occasionally. I want 650 rwhp minimum, and I want it to last. Oh, and I don't want it to bellow smoke all the time. I'm not concerned with the extra cost, as long as I am getting something for it.
I am scared to make the wrong choice. How easy is it to change turbos on the elite kit? will any t4 turbo bolt up? Is this a divided setup? I am a turbo kit virgin. Be gentle.
bigrpowr
<How I Fly
Administrator
well the precision turbos are definitely top notch, but at the moment not for offer if you're referring to the 2015 retro kit. I think you're getting the full turbo kit like MPD and elite offer , with the factory 2015 kit that this thread is about. pm me and I can get you straight on what your options are. its pretty simple, the 2015 kit , just retrofits the 11-14 to allow the factory 15+ kit to fit, allowing for the 15 turbo option which is a better turbo. the other kits are COMPLETE replacement units with new mounting , piping, downpipe, and intake. pretty much different animals. your goals should dictate what kit you choose. let me know if I can help more with clarifying. I sell them all !!
50_shooter
Central IL
This is the 11-14 master list thread. I have a 14. I will pm you.
Jd4455
Pa
Are the stock 15 turbos worth anything to you Morgan . I have 3000 mi on mine with no towing.
Jd4455
Pa
Ok thanks Morgan I will be contacting you when tunes are available for this truck
Stangr8cr
Is there somewhere to send a bearing failed 11-14 charger and recover the core charge? Only thing I held onto after the swap was the turbo in hopes of getting the core back for it.
Keith
Athens, IL
Elite Diesel:
Stock 2015 61mm turbo upgrade : $2799
Stock 2015 61mm turbo w/ billet wheel : $3499
Garrett GT3794 64.7mm turbo w/ piping, dp, air filter, and fuel filter relocate : $5200
Garrett GT4094 67.8mm turbo w/ piping, dp, air filter, and fuel filter relocate : $5600
Garrett Danville 72mm turbo w/ piping, dp, air filter, and fuel filter relocate: $6600
Fleece Cheetah 63mm turbo w/ piping, dp, air filter, and fuel filter relocate, Designed for 2.5 Sled Pulling class : $6400
Precision Turbo 6466 turbo (non vgt 66mm) w/ pedestal, piping, air filter, and fuel filter relocate : $6250
Precision Turbo 7168 turbo (non vgt 71mm) w/ pedestal, piping, 39mm wastegate, air filter, and fuel filter relocate : $7500
Precision Turbo 7668 turbo (non vgt 76mm) w/ pedestal, piping, 39mm wastegate, air filter, and fuel filter relocate : $7500
Industrial Injection:
ADDS a Borgwarner S475 turbo to your existing factory turbo and comes with everything needed : $4250
Midwest Diesel:
Stock 2015 61mm turbo upgrade 11-14 kit : $2799
2015 61mm turbo w/ billet wheel (TowMax) 11-14 kit : $3399
2015 61mm turbo w/ billet wheel (TowMax) 2015 : $2500
2015 64mm 6 blade billet wheel (StreetMax) 11-14 kit : $3799
2015 64mm 6 blade billet wheel (StreetMax) 2015 : $2900
S300 kit w/ 63 or 66mm turbo w/ piping and dp : $4150
S300 kit w/ 63 or 66mm turbo w/ billet wheel, piping and dp : $4550
S300 kit like above with NO turbo : $3425
Maryland Performance Diesel:
NON vgt turbo kit 63-71mm cast or billet, new exhaust manifolds and piping : CALL for pricing
Snyder Performance Engineering (SPE):
Stock 2015 61mm turbo upgrade w/ new bearings : $2999
Stock 2015 61mm turbo w/ bearing upgrade, all piping, new intercooler and tuning : $4500
