OBS 7.3 engine and pickup build HP goal is in the 600HP range
Powerstroke Cowboy
Montana
I am not shure if a got this in the right spot. So feel free to move it Mods..
Or you could tell me were to put it and I could move it..
Here is a list of what is going into the engine.. (yes it has changed a little)
ARP heastuds (in)
910 valve springs shimmed (in)
SB Push Rods (in)
Twin stealth HPOP (in)
140V IDM mod (in)
AirDog II fuel pump (in)
300/200 hybrid injectors (being built now)
T4 turbo mount kit (is in the pickup now for fabbing)
Chines GT4202 Turbo as the High pressure turbo (in right now for fabbing)
Borg warner S4TS508 as the low pressure turbo.. ( is being mounted now)
6.0L Intercooler (in)
99-03 Plenums (in)
dual filter air intake ( will be built after i get the S4T mounted)
Water injection to help with egts if need be (in)
Gauges, EGTs, HPOP, Fuel pressure, Transmission, and two boost gauges and a Exhaust back pressure gauge..
two 50mm Waste Gates on for the GT42 and one for the S4T ( I have them just need to mount them)
And tuning will be by Jody Tipton@DP-Tuner
If I am missing anything please let me know!!!
Like you all said a new thread a new start!!
Here are some pictures for yall to look at of the thing a have and of the things i have done.
GT42
Stealth twins and SD Plenums
new IPR
S4T turbo
ARP Head studs
Old injectors
More to come
Powerstroke Cowboy
Montana
Thanks!!
Yes it has stock forged rods and I am leaving the bottom end stock.. for now that is..
in the far futare
I would like to pick up a 7.3L block and build when i have the time and beaf it up. then switch all the parts from the engine i have now to the new engine, then get the injectors rebuilt to 400cc or maybe 465cc and go with 300% or 400%..
But that all depends on how good the setup i have now will work and how long it will last..
Powerstroked162
On Da Juice
Wa. State
Oh jebus chrys.... Please, refrain from copying and pasting all that mess from PSN to over here. We all are very aware of your build. Thank you
Powerstroke Cowboy
Montana
LOL ssshhh dont mention the P------------S----------N word and mess up this good site that just got started...
Like others have said new site new start...
Powerstroke Cowboy
Montana
Where some pics of your truck man?
I dont have any yet.. its kind of hard to get pictures in a dark barn.. AND i have about two feet on both sides to walk. about 5 in the back and 3 in the front..:doh:
I need more space!!
Besides i have the bed off right now and the rear axel tore apart.. I am doing lockers front and back and changeing the gearing out to 3.55s, and changeing all the seals and bearings in the front and back axel. and I am doing the brakes front and back to.. one of the back drums was in two pieces and both back brakes had no pad left on the brake shoe most of the metel on the brake shoes are gone to!!
Powerstroke Cowboy
Montana
here is what i am up to..
this is about were the turbo will sit, just about one inch higher.
I still need to finish the mount for the second turbo it is almost done though!!
My brakes are shot
The LS differantial and ring gear..
The new locker instaled in the Ring gear housing.
I will be doing the same thing to the front axle. new brakes and a locker.. new bearings and seals..
I will be doing more on monday.. since i have off work..
