Go Back   PowerStrokeArmy > Power Strokes > 94-97 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 01-02-2020, 05:52 PM
501 96 7.3's Avatar
501 96 7.3 501 96 7.3 is offline
Private
Member's Gallery
Default Engine rebuild or new truck?
My truck went down this summer. Engine went to machine shop and two main bearings were cooked and crank was blued there. I have been trying to work with swamps and that hasnít been to easy. Anyway looks like $10K for them to rebuild everything with good parts and dyno engine also. My local guy I donít really trust to put everything back together correctly.
I found a 17 with 40k miles for around $40k. XL truck but itís what I need cclb srw 4x4 F350.
I also found a used engine for $1K with an auto attached. Said to be running but who knows. I thought about doing a compression check on it and go that route.
Any suggestions welcome.
__________________
1997 f350 cclb 4x4 315/75/16. 4.10's zf 5. Rosewood 200/30. Efuel 3" SD plenum's. Irate T4 s366 6.0 factory intercooler. T500. Isspro egt boost. Dp Infinity. TS 6 gear head
  #2
Old 01-02-2020, 09:39 PM
wildbill963258's Avatar
wildbill963258 wildbill963258 is offline
Lieutenant
Member's Gallery
Default
Its completely up to you man, honestly I would say do the rebuild and while you're in there fix any other issue that you may have as well. My truck runs but has lots of blowby for only having 186k miles. So I'm gonna have mine replaced with a known good running engine and build it to 400rwhp as well as upgrade the transmission to a sd 6 speed and replace the rear end with one with a higher gear ratio. As well as fix all the other issues I have with mine. You might could try getting ahold of kcturbo they might be local to you.
__________________
'96 F250 ECLB, 2wd, Auto, DIY CAI, 3"DP for exhaust. Sadly sold
'94.5 F350 CCLB 2wd ZF5 DIY CAI 3" DP for exhaust and stock tunes for now
  #3
Old 01-02-2020, 09:45 PM
Lieutenant
Member's Gallery
Default
You could buy a newer truck but it all depends on how the previous owner or owners took care of it. That's one of the problems I'm running into with mine when I got my truck it had 166k miles on it but it had blowby even then which tells me the previous owners did not take care of it at all maybe had glowplug issues with it on cold mornings and used ether or didn't let it warm up before driving it like they stole it. I would consider getting a newer truck but I love the sound of the older motors and mine is getting ready to paid for and quiet frankly I dont want another truck payment.
__________________
  #4
Old 01-02-2020, 11:38 PM
JCart JCart is offline
Sergeant
Member's Gallery
Default
Really depends on what you want.... I Rationalize it as “Parts” or “Payments”. With parts you basically get to choose when you put dough into your rig. With a loan as in new truck, or one you have to borrow money on, you’re committed to payments every Month/bi-weekly or what ever.... I’m a parts guy and choose to bolt on stuff on, pay cash, buy tools and do the work myself generally. If you’re not in a huge hurry buy a known lower mileage engine and install yourself, then bolt on performance parts as you want them. With a used purchased truck you could be buying someone else’s problems and be in the same boat as now. Brand new or near new payments could be significant and in terms of add performance parts, my understanding EPA is getting tougher to deal with.
Cheers,
j
__________________
'97 F250 ECLB Tan White Tan Now ZF5 , 4:10ís, D60, PMF 3.5 RSK, 37Ē Toyo RTs Anti sways front/rear w rear bags 5Ē blocks (195,000 Kms) DP, intake, IC and 4Ē exhaust, FFD 205/30s, Hydra, E fuel, + other keerap.
Truck pix & Write ups
  #5
Old 01-03-2020, 01:58 AM
Lieutenant
Member's Gallery
Default
Plus there ain't nothing more satisfying than an old dinosaur keeping up and or beating the newer trucks
__________________
  #6
Old 01-03-2020, 06:18 PM
superpsd's Avatar
superpsd superpsd is offline
Major
Member's Gallery
Default
I read a post on another forum today that there is trouble t swamps. From what it said is people are waiting on parts and the owner was arrested for writing bad checks? Just a rumor so it could be B.S. Just something to look into. I would just drop in a running take out.
__________________
2020 F450 STX CCLB 4x4
1997 F250 TVS Supercharged, S369, R&D IDI T4 mount, my 350/200s, Honey Badger SR, my tuning, bmw m3 seats, RSK TTB, Toyo M/T
1948 GMC pickup Detroit 453T
1951 Mack A51T
1916 Federal 1 1/2 Ton
  #7
Old 01-03-2020, 08:08 PM
501 96 7.3's Avatar
Private
Member's Gallery
Default
I had bought studs springs and pushrods several months ago. I sent them back when I found out my engine was done. I have called swamps several times trying to spend more money with them and have left several messages. I have a credit for the returned stuff. Makes me wonder what is going on.
As far as putting a takeout in, is there anything to check besides compression? I found one already pulled from a wrecked truck. I know this is the cheapest route...cheapest ain’t always the best. Thanks for the replies
__________________
  #8
Old 01-04-2020, 12:33 AM
Lieutenant
Member's Gallery
Default
What happened to your original motor? Depending on how it went you could buy the takeout and check compression on it look for any obvious leaks and damage and check the condition of the main engine harness, and install it in your truck for now and then while you have the original out of the truck tear it down find out exactly what happened to it fix it and rebuild it to the way you want. Then put the original engine back in and sell the takeout to someone else who needs it.
__________________
  #9
Old 01-04-2020, 12:35 AM
Lieutenant
Member's Gallery
Default
Also while you have the engine out you want to go ahead and take a look at the flywheel and clutch/torque converter. If you have a manual transmission go ahead and replace the clutch while you have the motor unless you know for sure that the clutch is still good. Because it is a pain to do it while the motor is in.
__________________
  #10
Old 01-06-2020, 03:32 PM
501 96 7.3's Avatar
Private
Member's Gallery
Default
Anyone have any info on J&K engines? They are out of Mt Juliet TN. They sell long blocks for a reasonable price. I think I would rather go with a rebuild than put a used engine that I know nothing about.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
