Go Back   PowerStrokeArmy > The Bunker > General Discussion Forum
Reply
Thread Tools Display Modes
  #1
Old 02-05-2020, 08:00 AM
ghohouston's Avatar
ghohouston ghohouston is online now
Colonel
Member's Gallery
Default Flashlight
Guys, my streamlight has finally given up the ghost after about 10 years, and really dont want to spend that kind of money on another light. What do yall use that will hold up to lots of abuse? I.e. working on heavy equipment
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2018 Ram 5500 Mechanics Truck
2001Tdi Jetta 5 speed
  #2
Old 02-05-2020, 10:43 AM
Arisley's Avatar
Arisley Arisley is offline
Mod Squad
Member's Gallery
Default
Check Streamlights warranty.
__________________
E99 ECLB Dually, 2010 bed, 2005 headlights, smoked clearance lights, 2001 cup holder.
365,XXX miles. Pure stock, sorta.
SDRCM #478
PSA Conspirator # 22
  #3
Old 02-05-2020, 07:39 PM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
How big?
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, S471, Beans IDM, ARP head & main, girdle, half filled block, DI cam, Dual IPRs, ceramic coated bowls, anti-friction skirts, Haldex pump over Stock pump, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #4
Old 02-05-2020, 08:34 PM
Diesel625 Diesel625 is offline
Sergeant
Member's Gallery
Default
I’ve always liked the streamlight protac hl3. You can find them for around 75 online. Ive bought hugsby lights that were pretty much the same flashlight for almost half the price.
__________________
2019 f350 cc Drw fx4 ultimate, 1 pmf, airlift 1000, Ride rites, ranch hand, Schaeffers 10w30, 295/70r17 toyo mt, no limit, gdp, MBRP.
2006 f350 drw fx4. Kd stage 1 block, Kc stage 1, Colt stage 2, kd pushrods, 80# springs, arp, oringed heads, 175/stock, 6.4 banjos, sct 5015, quick trick and tsd tunes, 5 cat back, ford blue spring, bpd fan clutch, bd up pipes, atlas 40, egr gone, 2 level, 4 pmf blocks, Ride rites, cm bed, Schaeffers 5w40, 295/70r17 toyo mt.
  #5
Old 02-05-2020, 09:17 PM
6.0 Tech's Avatar
6.0 Tech 6.0 Tech is offline
Colonel
Member's Gallery
Default
I think streamlight is lifetime warranty. At least on the stingers. Hell, about the only thing they dont cover it seems is dumbass (guy at work tried warrantying one he ran over with a forklift or something stupid) and the lenses. Hell they warrantied one I left wedged in between a frame and *** and melted the switch...
Sent from my VS988 using Tapatalk
__________________
04 cclb IDP and TSD tunes, KC Stage 2 hi pressure, S476 atmosphere, Odawg Stage 2 ported intake, RCD Stage 1 cam, RCD lifters and pushrods, RCD 120# valve springs, ARP 625s, o ringed heads, Warren 7mm 250/100 hybrids, Strictly bowl dereete regulated return, Air Dog 2 4g, Snow stage 2 water/meth
  #6
Old 02-05-2020, 11:10 PM
ghohouston's Avatar
Colonel
Member's Gallery
Default
Wow I didn't know they had a lifetime warranty but I see now. I figured as long ago as I got it, there wouldn't be warranty left. Mine is a Stinger DS. As far as size, from google looks like just under 9 inches long
__________________
  #7
Old 02-08-2020, 05:48 PM
CTFFEMT's Avatar
CTFFEMT CTFFEMT is offline
Sergeant
Member's Gallery
Default
send it back to streamlight. they will fix it. I just had my survivor fixed. took a couple weeks to get it back, not too bad. I had to pay for shipping but that was it.
https://www.streamlight.com/support/...ervice-options
__________________
2000 7.3 ZF6 4x4
MBRP, GH, Rosewood, Borg Warner, Carillo, diesel innovations, Riffraff, Mahle, Terminator, cooling mist, south bend, melling, comp cams, ARP, Irate, Dyno Proven, Mag-Hytec, PMF
  #8
Old 02-09-2020, 10:40 PM
ghohouston's Avatar
Colonel
Member's Gallery
Default
I will definitely do that. Thanks yall
__________________
  #9
Old 02-10-2020, 08:57 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Quote:
I use a coast pen light. Love it. Its stout too. Its been dropped all over equipment and log trucks. Its 2 AAA batteries though. Not sure if you need a rechargeable or not.
Recently grabbed a couple light from harbor freight. The rechargeable pen light and the led flashlight that is close to the same size but has a belled head are both very good options for the price! Less than 15 bucks and less than 8 bucks.
The coast was like 18 er something from home depot. Been using it for the past 5 years.. it has a inspection(spot) beam also not a flood beam like the rest.. be worht trying out while the streamlight gets worked on.
Sent from my SM-G977U using Tapatalk
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #10
Old 02-10-2020, 09:06 PM
General
Member's Gallery
Default
Clean out your pm box
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
