Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #21
Old 01-11-2020, 07:04 PM
dsberman94's Avatar
dsberman94 dsberman94 is offline
General
Member's Gallery
Default
Irate diesel kit is what I bought. Comes with Upgraded draw straw, fittings, hose, their billet filter, water separater, and pump mount, regulator to head fuel lines, return line with quick connect fitting for the return. I think I got the upgraded pump but thatís optional. You can get a tank sump set up from them as well but I preferred the draw straw.
Cnc fab also makes fuel line kits as well as HPO line kits. They make a few different kits with quality parts. Worth checking out.
__________________
02 F250 7.3 Crew Cab Short Bed Lariat
PHP Hydra, Ge4rhead tunes, Edge insight CTS monitor
Mild Trans Build, Dual disc TC
GTP38R, T500, PIS 175/80s in the engine. waiting to see rods one day
Turned 200k miles 1/18/2015
  #22
Old 01-11-2020, 08:07 PM
wildbill963258's Avatar
wildbill963258 wildbill963258 is offline
Lieutenant
Member's Gallery
Default
That is not a regulated return system that is a fuel lift pump that helps get the fuel from the tank so the regular fuel pump doesn't strain as much when you go wot and demand more fuel from the pump (well that's my theory anyway on why they sell these products but I do know for sure that it isn't a regulated return and that it is a lift pump). A regulated return looks like a little aluminum block that goes where your fuel filter housing used to go.
__________________
'96 F250 ECLB, 2wd, Auto, DIY CAI, 3"DP for exhaust. Sadly sold
'94.5 F350 CCLB 2wd ZF5 DIY CAI 3" DP for exhaust and stock tunes for now
  #23
Old 01-11-2020, 08:28 PM
Big Red Bus Big Red Bus is offline
Private
Member's Gallery
Default
Quote:
Haha yeah after I posted it I started doing some digging on ther websites and yeah it is a lift pump which I dont understand why it says direct replacement when I have only found one pump on my truck and from what I have seen there is no pump in the tank on the powerstrokes.
Sent from my SM-N960U using Tapatalk
  #24
Old 01-11-2020, 09:35 PM
Lieutenant
Member's Gallery
Default
There isnt, the pump on sd and excursions are on the frame rail ( or so I think I could be wrong)on obs they're on the motor.
__________________
  #25
Old 01-11-2020, 09:37 PM
Private
Member's Gallery
Default
Yeah I got one on the driverside rail that's all I found
  #26
Old 01-11-2020, 09:38 PM
Lieutenant
Member's Gallery
Default
The regulated return I think goes in place of the fuel filter bowl.
__________________
  #27
Old 01-11-2020, 09:40 PM
Lieutenant
Member's Gallery
Default
You could make or have made a bracket to hold the 2 pumps and fuel filter and fuel water separator
__________________
  #28
Old 01-12-2020, 08:39 PM
Tom1850 Tom1850 is offline
Private
Member's Gallery
Default
I built my own fuel system with an Aeromotive A1000 marine pump and bought the fuel lines from Swamps. The filter heads are just generic with Napa filters. It saved me bookoo bucks. If I was going to do this on a newer truck and had over a grand to lay out for the project I'd go with a Fass Signature series. You can't beat Fass for quality IMHO.
Sent from my Pixel 2 XL using Tapatalk
__________________
1997 F350 purt near plumb built but has trans problem
1997 F-250 mostly stock
2012 F250 6.7 aggravation gremlin truck
  #29
Old 01-12-2020, 10:10 PM
Private
Member's Gallery
Default
Yeah I checked out the fuel systems they are pretty spendy the basic one is 675 plus parts and harness, and it's only 67gph, does anyone know what the stock pump runs gph? Also looked at the regulated return and its compression fittings, Im Not a fan of compression as guys at work will find a drip and then over tighten and then it leaks more and boom your fabing a new line to replace the one they wrecked. So I'll probably just make my own as I'm kinda a snob on hardlines. Looked at the a1000 pump for marine applications and it does 105gph will see if I can find a cheap one will probably run cat separator and filter as we had good luck with them at work.
  #30
Old 01-13-2020, 12:46 AM
Lieutenant
Member's Gallery
Default
I think dual stock pumps will be enough for your injectors but I may be wrong I'm not real sure
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
