Go Back   PowerStrokeArmy > Power Strokes > 94-97 Tech
Reply
Thread Tools Display Modes
  #21
Old 09-13-2018, 09:09 AM
wildbill963258's Avatar
wildbill963258 wildbill963258 is offline
Sergeant
Member's Gallery
Default
The problem is it doesn't stay in one area or another area of the gauge for more than a couple of days. Some days it reads around the r, m area and some days like yesterday it will hang around the n. I'm thinking my thermostat is showing signs of age and is sticking closed a little longer than it should be.
__________________
'96 F250 ECLB, 2wd, Auto, DIY CAI, 3"DP for exhaust. Sadly sold
'94.5 F350 CCLB 2wd ZF5 DIY CAI 3" DP for exhaust and stock tunes for now
  #22
Old 09-13-2018, 09:16 AM
Sergeant
Member's Gallery
Default
The only reason I'm thinking it's an issue now is because I'm having to go under the hood and fix my uvch again. And the right bank that has the aftermarket VC gasket and uvch is just fine but the left one even with a good OEM gasket and uvch like I explained earlier in this thread doesn't seem to want to VC gaskets and uvch's for very long. Something is breaking down the connection on that side of the motor and the only thing that comes to my simple little mind (plus I work with plastic everyday) is heat.
__________________
  #23
Old 09-13-2018, 11:12 AM
superpsd's Avatar
superpsd superpsd is offline
Major
Member's Gallery
Default
I run the motorcraft 195° stat. I would never want to run a hotter stat. I rather keep things a little cooler. The 195 actually starts to open at 175ish°. My 7.3 when lightly loaded and idling stays right around the N which shows 176° with a IR thermometer typically. When I heavily fuel and tow it will move up towards the M. If you can read EOT that is another good way to see temps as EOT typically stays pretty close to coolant temps if everything is working good.
__________________
97-250 7.3 Eaton TVS Supercharged, S369sxe, R&D IDI performance T4 mount, my B350/200s, Honey Badger SR with My tunes, BMW M3 seats, Sky 5" RSK skyjacker drop pivot brackets, Sky shackles and hangers, Toyo M/T
1948 GMC Detroit 453T
1951 Mack A51T
1916 Federal 1 1/2T
  #24
Old 09-13-2018, 07:34 PM
Sergeant
Member's Gallery
Default
Well just an update it's the outer harness for those back 2 injectors
__________________
  #25
Old 09-14-2018, 02:49 AM
Garbage_Mechanic Garbage_Mechanic is offline
Sergeant
Member's Gallery
Default
Halfway through reading this thread I was ready to ask you if you had checked or replaced the plugs on the chassis side of the VC.
One thing that really helps glow plug harnesses last is updated programming that shuts off the glow plugs sooner when EOT is up. There used to be a kit with a water temp switch too but any modern tune will update it too.
(still on the originals on the 96 at least since 2002 when I got it)
__________________
Mine since 2001: 91 F250 RC 4x4 5spd 7.3 IDI 4.10LS Banks Turbo Electric Fuel 92 D60 w 97 brakes and Powerlock Hydro boost Flatbed
Hers since 7/03: 96 F250 CCSB 7.3 PSD 4x4 5spd 3.55 LS D60 AMP Powersteps Currently ungoing 22 yr Rehab Incl Swamps Long Block, S364.5, IC, RSK etc.
2 Harleys 7 Horses about 50 cows +-
Diesel Mechanic 40 yrs
Now 120 truck Fleet, 80 plus CNG powered
  #26
Old 09-14-2018, 07:45 AM
Sergeant
Member's Gallery
Default
The front plug has been recently replaced on that side because when the original problem started that plug was trashed. But the back plug was still good at the time.
__________________
  #27
Old 09-14-2018, 01:49 PM
Sergeant
Member's Gallery
Default
Well replaced the back pigtail on the left bank and still has a miss after swapping out uvch's yesterday. So now I'm stumped. I haven't spent any money on these parts these were all left over from trying to fix it earlier this year. The gaskets and uvch's were bought used but only 10k miles on them and all look to be in good condition none of the connections crumbling or anything like that.
__________________
  #28
Old 09-14-2018, 01:53 PM
Sergeant
Member's Gallery
Default
I'm about to the point of just replacing the entire harness and VC gasket and ucvh's with all new parts or good known parts
__________________
  #29
Old 09-14-2018, 11:34 PM
Calico5's Avatar
Calico5 Calico5 is offline
Private
Member's Gallery
Default
Quote:
That's probably your best bet. Get Ford OEM UVCH/gaskets. Stealership, or from that "diesel_site" that sells diesel stuff on the interweb...
Also, consider: your temp gauge is reading engine coolant temp, but your UVCH is exposed to hot engine oil, which is usually a bit hotter than your coolant.
Lastly, the wiring in the UVC harness must be carefully and correctly routed and zip-tied together (as the factory ones are) to keep them from chaffing on the head, injectors,glowplugs, etc. It's worth the extra few bucks to get OEM.
__________________
Al in SoCal
AFE Intake; Garrett 38R; DieselSite Turbine Jacket; Banks IC, BanksBrake
External Oil cooler & Remote filter; Stealth 4-line Twin HPOP, Melling LPOP
Swamp's: AC's 160/30% & HVHF IDM; DP-Tuner F5
Full R-R Fuel System, Pre-& Post-pump filtration
Mishimoto Rad & Tank; 4" Exhaust
SouthBend D-D Clutch; ZF 6-spd, GearVendors O/U Drive
  #30
Old 09-15-2018, 12:27 AM
Sergeant
Member's Gallery
Default
I have OEM on the problematic side that only has 10k miles on it with the exception of the engine harness (which is original to my truck and shows signs of being messed with) I can unplug the back pigtail on the problematic side and the engine will run fine just on 6 cylinders but if I plug the back pigtail back the IDM will shut that entire bank off and on. And when the IDM shuts that bank off it will of course throw the CEL
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
