HELP Truck only runs with key on Crank Position
ZF6_7.3
CT
As said above, 1996 auto 2wd only runs when the key is in the CRANK position. I just did a T4, HPOP and EFUEL in my truck. I cut out the fuel bowl wiring and wired in the IPR directly.
Now the truck does this. Any help?
KBMKVIII
Texas
Check your fuses?
May be a stupid question but a good place to start.
Also the wires you cut, how did you insulate them from grounding out or shorting to ground?
KBMKVIII
Texas
Also are you sure you did not mix up the exhaust back pressure valve wiring with the icp?
They look the same because they have the same plug
