Alternator signal on cluster PCB?
Tanker3278
Plattsburgh, NY
Anyone know where the signal runs through the PCB in the instrument cluster? I can take more pictures if needed.
I've already changed the alternator, charged the batteries, checked continuity & fuses on PDB and under the dash. Still only charging at 12.5v.
Sent from my LM-Q620 using Tapatalk
bryan.d
S.E. Louisiana
Not sure where it runs they the pcb board. Do you have constant and switched 12 volts at the 2 wire connector on the alt? One is powered through a fusible link at the starter solenoid and the other is fused. There are ton of videos on YouTube. There is one video that has a damaged wire for the optional 2nd alternator under the hood that cause the alternator not to charge.
