Steering knuckle
blackcloudpsd03
I went to replace my tie rod yesterday and noticed the tapered tie rod hole in the knuckle was egged out thus the new tie rod wouldn't work lol so with that being said is there any fix to this?
I checked eBay local junk yards etc... nothing ... I can find dana 50 all day but not dana 60's
cpadolf3
Can you post a picture of it?
Sent from my SM-G935V using Tapatalk
mikeeg02
Drifting, PA
Iirc, the knuckles out are the same from d59-d60. The only difference between the d50-d60 is ring gear size and axle shaft spline count at the carrier
not enoughsmoke
lynnville tn
Ruff Stuff Specialties make inserts
On 97 and down they are NOT the same
98 and up are interchangeable up to 04
blackcloudpsd03
Sorry about that I never changed my sig. No I don't have a picture because it's still moveable I can find dana 60 king pin all day I just can't find ball joint ones.
Does anyone know the sizes of what a factory tie rod hole is how big to drill it etc? I have found inserts but I didn't know the sizes
blackcloudpsd03
It looks like the only move I have is the inserts but even then all I find is GM inserts even off ruff stuff
JohnT24
OXFORD CT.
This happened to me more than a few years ago
I bought an insert I believe from ruff stuff
I used a tapered reamer to clean up the egged hole
Then tapped in the insert.
It has worked fine for years now.
Sent from my iPhone using Tapatalk Pro
blackcloudpsd03
do you recall what one you got?
Did you have to use a different tie rod end or did you use the factory ford tie rod? I pulled the knuckle off tonight I'm debating on sending it to my machine shop to weld it then re taper it vs doing a insert
JohnT24
OXFORD CT.
Sorry, I don't remember exactly what I bought...
only that it was an insert to match the Ford tie rod end.... for putting a ford front end in a jeep or some other type of conversion...
blackcloudpsd03
There she is LOL
JohnT24
OXFORD CT.
Can't get a used one at the boneyard?
just for curiosity.... have you looked up how much a new one is?
