Platinumf250
Have a 3" rough country lift on my truck now with their spacer, radius arm drop brackets, and trac bar drop bracket. The brackets have two holes in them to set the arms at different heights if need be I'd assume. Would it be possible to pull the 3" spacer and put a 4.5" icon coil in instead? Maybe have to move the drop brackets to the next hole? If you could put a 1.5" level on a stock truck and not change anything couldn't you add 1.5" to a kit designed for a 3" lift?
Want to do a 3 link or I saw some Carli radius arm drop brackets for sale here too.
Would the ride be better with a 3 link, icon coils, and my 2.0 fox shocks, or better with icon coils, drop brackets, and 2.5" fox resi shocks?
