kc daylighter bulbs
johndeerezach
wellman,IA
has anybody put the 130 watt bulbs in the lights that had 100 watt bulbs in them? i have 100 watt bulbs and want to switch to 130 watt bulbs but didnt know if they were set up the same or not. thanks for looking
johndeerezach
wellman,IA
ok just for future information kc does say that you can put the 130 watt bulbs in the daylighter series long range light housings that were 100 watt to start with. contacted them direct but the wiring to hook it up needs to be larger not at the housing but everything that is extra in those kits. the 130 watt bulbs produce 285000 candle power per light so 4 lights is guna be brite as chit!!
