Go Back   PowerStrokeArmy > The Bunker > General Discussion Forum
Reply
Thread Tools Display Modes
  #1
Old 08-10-2018, 06:55 PM
CTC DEEZUL's Avatar
CTC DEEZUL CTC DEEZUL is offline
General
Member's Gallery
Default Official Tech section thread
maybe this will take off, maybe not, maybe sticky? well see
Purpose of this is to basically have all our techs chime in on all different brands. No I dont just work on PSDs, Im all across the board as far as light duty/medium duty goes.
Ive got a 5.2L Isuzu with major after treatment problems. Was at the dealer but customer pulled it out. Im tossing a new *** and SCR on. The *** was absolutely toast and suspect some sort of thermal event. I had soot on tail pipe, through SCR, everywhere, coked up.
while the exhaust was off I did several cold starts and throttle snaps. smoke is about normal, with a little puff of black as expected on enrichment. Injector balance rates are off as far as the dealer is telling me. They like to see ~2.5. Ive got 2 cylinders both hot and cold are 4.5 posi and neg. so those are definitely not helping.
after new ***/SCR was on, I cleaned the differential psi sensor and cleared some stored values. Within 10 miles my Particulate Matter gauge pegged and a regen started. I let it go since I couldnt pull off and shut it down. Theres no way this filter plugged, I only had 10kPa under a full load accel.
shortly after this i reconnected to truck and have a code for *** diff psi sensor circuit high, its now reading 110kPa engine off! So no wonder why the PM gauge is reading high as hell!
Waiting on the sensor now, that should fix this, but I am open to any other thoughts here on possibly why the prior *** that the dealer put on failed.
197k miles. 9300 hours!!
this is the OUTLET of the SCR!
__________________
Teamsters Local 444- Rolling Coal United
  #2
Old 08-10-2018, 07:58 PM
6.0 Tech's Avatar
6.0 Tech 6.0 Tech is offline
Colonel
Member's Gallery
Default
Where is all the oil from?
__________________
04 cclb IDP and TSD tunes, KC Stage 2 hi pressure, S476 atmosphere, Odawg Stage 2 ported intake, RCD Stage 1 cam, RCD lifters and pushrods, RCD 120# valve springs, ARP 625s, o ringed heads, Warren 7mm 250/100 hybrids, Strictly bowl dereete regulated return, Air Dog 2 4g, Snow stage 2 water/meth
  #3
Old 08-10-2018, 08:46 PM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Oil?
That's soot
__________________
  #4
Old 08-10-2018, 10:05 PM
6.0 Tech's Avatar
Colonel
Member's Gallery
Default
****, looked wet, my bad... You said the bad injectors were bouncing negative? Others possibly overfueling to a point?
__________________
  #5
Old 08-10-2018, 10:09 PM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
A -4 and a +3.5. buuuut I've been told Isuzu only allows 2.5 just to keep the after treatment in good shape. It's honestly not enough deepeeeff for a 5.2L engine. So technically a dealer would be replacing these.
I definitely agree, but it is not the issue here.
__________________
  #6
Old 08-11-2018, 08:10 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
This could be useful.
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #7
Old 08-11-2018, 08:48 AM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
I suggested something like this awhile back, basically for all the techs only to knock noggins on issues. Keep the riff Raff out and avoid the "well im not a diesel mechanic but hope you find your problem" commentry out of here....
__________________
  #8
Old 08-12-2018, 03:56 PM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Quote:
I guess I'm out! Lol
Sent from my SM-G955W using Tapatalk
  #9
Old 08-12-2018, 04:11 PM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Stop!
__________________
  #10
Old 09-20-2018, 05:40 PM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Junk dodges.
6.7 with loaded *** codes. Can't run a gen, clear timers, idle it, 4300 seconds on the counter. Take it for a drive, stupid witech times out as soon as you leave WiFi so you can't watch your soot time. Halfway down the street it coded out and threw me in derate. Got back to shop, re cleared timers again.
Regen won't happen until 25000 seconds on the timer. So I cleared them and just held wot. Timer went from 100 seconds to 24000 seconds. By time I switched screens to start a Regen, it already coded out. FML.
Anyone deal with this?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
