Go Back   PowerStrokeArmy > Power Strokes > 7.3 Tech
Reply
Thread Tools Display Modes
  #1
Old 11-08-2011, 09:18 PM
PatriotHauling's Avatar
PatriotHauling PatriotHauling is offline
Sergeant
Member's Gallery
Default How to: Power Steering Flush (Video)
Here is my video on power steering flush procedures!
This was easy, took about 2 hours from popping to hood to slamming it closed, and that was with me filming!
Results were great! Brake stiffened up quite a bit and steering quieted a little.
Enjoy!
__________________
- Trey
2002 F250 XLT CrewCab Short Bed 4x4 7.3L
Phoenix 6pos (Stock, 65dd, Whisper, 100p, 120r, 80t), 6637 Intake, RR-IC Boots, BW CPS, DeFoiled, 08 Tail Lights, MBRP TB 4" w/ muffler, Firestone load bags, 05+ Tow mirrors, Custom Flag Mount
My Youtube videos
  #2
Old 11-11-2011, 06:33 PM
CGMKCM CGMKCM is offline
Sergeant
Member's Gallery
Default
Great job on the video and filming. I would discuss in the narrative the hydro boost brake system and why it is important to pump the brakes while changing the power steering fluid. I have seen where flushing was recommended every 40k miles. Again great job doing the filming and wrenching.
__________________
01 F-550 Lariat 4X4
BTS, H2E/WWII, PHP tunes
2002 Golf TDI
.205 (110 hp) injectors, TD tuning Stage 3 tunes
EGR ******, V-6 clutch
  #3
Old 11-11-2011, 06:40 PM
Sergeant
Member's Gallery
Default
Quote:
Thank you. If you noticed, in the video I said I would NOT be using the steering wheel, but you will see me use the steering wheel twice. This is because I decided I wanted to get that fluid moving too, as well as the brakes.
__________________
- Trey
My Youtube videos
  #4
Old 03-29-2012, 08:35 PM
spongebob915's Avatar
spongebob915 spongebob915 is offline
Lieutenant
Member's Gallery
Default
What do the brakes have to do with changing the power steering fluid?
__________________
2013 ccsb f250 platinum 6.7
Morgans Streetmaxr
Morgans tuning
Full ******
  #5
Old 03-29-2012, 09:46 PM
purpleheart350's Avatar
purpleheart350 purpleheart350 is offline
Major
Member's Gallery
Default
Vacuum IIRC
__________________
2001 Excursion, 4x4, 230k miles, front x-springs, rear 350 dually springs, GTP38R, 6637, riffraff HPx and FRx, areoforce scangauge for boost and trans temp.
  #6
Old 03-29-2012, 09:50 PM
BigAlsPSD's Avatar
BigAlsPSD BigAlsPSD is offline
Lieutenant
Member's Gallery
Default
Quote:
The hydroboost system uses the same fluid from the "power steering pump" to assist in braking. Pumping the brakes while turning would ensure that all portions of the system were flushed. These motors do not use a vacuum booster as you would on a gas car, getting vacuum from the intake.
__________________
Alan
2000 F-350 SRW CC, Short Bed 7.3PSD BTS Trans, Van Turbo, 6/6 wheel, Tyrant Tuning, 290,000 miles and counting
  #7
Old 03-30-2012, 02:41 AM
Lieutenant
Member's Gallery
Default
Thanks
__________________
Morgans Streetmaxr
Morgans tuning
Full ******
  #8
Old 04-01-2012, 10:23 AM
Tom S's Avatar
Tom S Tom S is offline
Mod Squad
Member's Gallery
Default
In watching your video it looks like you only get fluid out of the system when you pump the brakes. What I have done on my OBS and other Fords in the past is pull the return off at the reservor and cap the nipple. I then extend the return hose to a drain container. I then use and air ratchet with an allen bit on it to spin the pump. That allows more control then doing it with the engine running although I have done that as well. It flushes out pretty quick when you do it this method. I am wondering if that combined with working the brack would work on a SD.
  #9
Old 04-01-2012, 11:14 AM
Zmann's Avatar
Zmann Zmann is offline
Colonel
Member's Gallery
Default
it only discharges fluid when you turn the wheel or pump the brake atleast on mine I can't imagine the 7.3 is different
this makes it easy and lets you leave the truck run while you top off the fluid without fear of running the pump dry ,, I suggest jacking the front end up to relieve the tires scrubing when going lock to lock.
some of the new ford diesels went back to regular booster brakes and a vacuum pump = yuk
I used this procedure but I didn't need a helper on my 06
http://www.superdutypsd.com/power_steering_flush.php
  #10
Old 04-02-2012, 01:22 AM
lukesdiesel's Avatar
lukesdiesel lukesdiesel is offline
Sergeant
Member's Gallery
Default
Nice Video
Luke
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
