Radiator Trans Fittings
06Mike
I bought the Performance Radiator for the 03 because it is all aluminum, it is going in my 2006. I knew it would have the wrong transmission fittings. I ordered some of the Dorman 800-617. When I was prepping the radiator fittings they were the wrong ones. What are y'all doing for the fittings? Are you swapping out the ones from the original radiator or does someone have the correct part number? Thanks for the help.
06Mike
Solved. Performance Radiator has a kit to convert the radiator. The kit is #111.
