obs Up pipes
gnxtc2
Bergen County, NJ USA
Very easy......remove turbo/DP and they drop right in....looks are deceiving
I tried new OEM donuts...they leaked, tried the Beans brass donuts...they leaked. Int'l has bellowed up-pipes for the OBS in the price range of $900. Int'l part# 1843486C92. Bar None Diesel makes a copy of the Int'l pipes but they are out of stock. http://www.barnonediesel.com/index.php?route=product/product&product_id=30
Junk
Irate one-piece (sold them when I went T4)
Billy T.
[email protected]
dillpurdy92
Junk
Billy T.
[email protected]
Well dang. Those look better than getting riff raff ones and a new collector. (Less leaks without collector)
1994.5 CCLB zf5
Lt.Dan
Visalia, CA
I have the riffraff ones, and they are a fantastic product! No leaks even after pulling them off and reinstalling twice with the same gaskets they came with! Id highly recommend!
old man dave
Petaluma, CA
Being that I replace my stock gaskets every 50k, the bellowed sets sound pretty good especially if you replace the uppipes with factory.
Fiveohmatt
I went with new riffraff
how was the install?
Lt.Dan
Visalia, CA
I cheated on my install, i was installing a Tranny at the same time, so access was a breeze, i didnt even remove the turbo.
With the tranny on, I've heard pulling the turbo is the best option. Then you can get to all the bolts pretty easily. Hardest part is just getting all the old bolts out. I've heard some people end up having to cut every one! I was lucky and they all came out with a little persuasion. Just be sure to soak them in some Liquid wrench or some kind of penetrant for a few days before working on them!
It comes with new bolts as well, just be SURE you use anti-seize on the bolts, or they will be a b*tch to get them out in the future again!
Good luck!
