Go Back   PowerStrokeArmy > Power Strokes > 7.3 Aftermarket
Reply
Thread Tools Display Modes
  #521
Old 01-14-2018, 07:05 AM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
Am I wrong in thinking that having a honey badger jr pump that “should” be putting out more pressure than a stock pump and putting another big high output pump on top of it is too much oil for my 300/200’s and that’s why I have too much oil and can’t rid of it? I would think that if I got a high mileage 15* pump i wouldn’t have the same problem.
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, Garrett GT4294, Beans IDM, ARP head & main, girdle, half filled block, DI cam, Dual IPRs, ceramic coated bowls, anti-friction skirts, Haldex pump over Honey Badger Jr, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #522
Old 01-14-2018, 07:27 AM
DieselJpower's Avatar
DieselJpower DieselJpower is offline
Lieutenant
Member's Gallery
Default
The Jr is a time bomb regardless, plus it might have paraphernalia inside it.
Get a bosch 17į or an adrenaline. It's not that the Jr is putting out more then stock pressure, it's the gen3 is so beast mode. In tuning mine I know exactly what a tune calls for, but I'll regularly see 300-500 more psi then desired. Call Matt and ask what the tunes are calling for, he might need to pull it back some. You should also figure out what model halidex pump you put on there. When I bought mine used, I sent it to swamps for a check up and they said mine was 1 of about 5 they built that had a pump "too large" on it. Too much pressure and it caused issues with ipr and wasn't recommend except maybe for sled pulling with huge injectors.
__________________
Josh
02 CCSB F350 4x4 -- GONE
04 Excursion 4x4 -- GONE
05 Excursion 4x4
19 CCSB F350 4x4
  #523
Old 01-14-2018, 07:47 AM
Magnum PD's Avatar
General
Member's Gallery
Default
My pump is a 4F665 pump. What it calls for.
__________________
  #524
Old 01-14-2018, 07:59 AM
DieselDC's Avatar
DieselDC DieselDC is offline
Sergeant
Member's Gallery
Default
Have you all looked at the pump swamps builds? Itís $1600 - thatís the one Iím salivating about but donít ever see anyone write about.
  #525
Old 01-14-2018, 08:36 AM
Magnum PD's Avatar
General
Member's Gallery
Default
I tried to imitate it.
__________________
  #526
Old 01-14-2018, 09:59 AM
Powerstroker7.3's Avatar
Powerstroker7.3 Powerstroker7.3 is offline
Lieutenant
Member's Gallery
Default
With running a gen3 pump the only purpose of the stock pump is to crank the truck. After that the gen3 kicks in and it doesnít matter what hpop you have. A stock Bosch or a used stock pump is just fine. Thatís all I have is a used 17 degree pump
__________________
350/200 custom 75mm bts 4r100 fully built motor by PDP
7.43 @ 94 CCSB
  #527
Old 01-14-2018, 10:35 AM
Magnum PD's Avatar
General
Member's Gallery
Default
If can find a cheap pump, I’ll see if makes any difference
__________________
  #528
Old 01-14-2018, 03:59 PM
psduser1's Avatar
psduser1 psduser1 is offline
Colonel
Member's Gallery
Default
To clarify, "too large" simply means that the relief system will not maintain desired pressure, i.e. 3-500 too much psi, lol.
__________________
2000 f250 zf6, air, oil, fuel mods, flatbed dual dana 80
Almost stock
2001 f250 same setup as the 2000, auto trans
2002 with a couple of mods, grocerygetter
  #529
Old 01-18-2018, 05:52 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Quote:
I believe that is why it needs dual ipr's.
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #530
Old 01-18-2018, 06:50 PM
Magnum PD's Avatar
General
Member's Gallery
Default
Where can I find info on the dual ipr setup? Can I do it?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
