Go Back   PowerStrokeArmy > Power Strokes > Aftermarket Super Duty 1999 - Current
Reply
Thread Tools Display Modes
  #1
Old 03-24-2019, 09:13 AM
Hillbillyshakespeare's Avatar
Hillbillyshakespeare Hillbillyshakespeare is offline
Private
Member's Gallery
Default What turbo do I have?
Going to do an EBPV ******. Since this is an “early 99” E series, did it come with a bigger turbo from the factory like I have read and I need the 99.5 kit or?
  #2
Old 03-24-2019, 09:48 AM
ghohouston's Avatar
ghohouston ghohouston is offline
Colonel
Member's Gallery
Default
Early 99 van turbo. Those "lines" if you will, around the compressor housing, are only present on e99 and obs turbo's. You can also tell by the 2" intake plenums, vs the later style had 3".
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2018 Ram 5500 Mechanics Truck
2001Tdi Jetta 5 speed
  #3
Old 03-24-2019, 09:53 AM
Private
Member's Gallery
Default
Quote:
Ok, so The kit from Full Force should be suffice then. Correct? https://shop.fullforcediesel.com/ebp...*-kit-early-99
  #4
Old 03-24-2019, 09:59 AM
ghohouston's Avatar
Colonel
Member's Gallery
Default
https://shop.fullforcediesel.com/ear...al-700296-0007
The link you posted won't open for me. This is a e99 ****** pedestal, but shows out of stock.
__________________
  #5
Old 03-24-2019, 11:22 AM
T_W6.7's Avatar
T_W6.7 T_W6.7 is online now
Corporal
Member's Gallery
Default
it won't open due to the software that thinks certain words are bad words and it automatically changes them to *****
__________________
2013 6.7- Midwest Diesel and Auto supplied Turbo and Fueling mods
  #6
Old 03-24-2019, 01:33 PM
Private
Member's Gallery
Default
Do I not need the new exhaust housing?
  #7
Old 03-24-2019, 01:37 PM
ghohouston's Avatar
Colonel
Member's Gallery
Default
Quote:
No. Cut out your ebpv valve, and pop 2 freeze plugs in. I think actually, if you cut the valve shaft enough, you can leave the bottom plug thats already there, and only need to get 1 freeze plug. Or it's the top one that can stay, been too lomg since I've done one.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
