Go Back   PowerStrokeArmy > Non - Specific > Welding & Fabrication Forum
Reply
Thread Tools Display Modes
  #11
Old 04-11-2017, 12:46 PM
Dirtclod's Avatar
Dirtclod Dirtclod is offline
Lieutenant
Member's Gallery
Default
Any stock machine @200 amps DC . Reverse polarity with a scratch start rig. And purge it. Or else you'll sugar it inside. Hell schedule 10 stainless you pretty much fuse it together
__________________
01 F-250 4x4 cc/sb 238/100 inj,adrenaline hpop,reg return fuel system,s&b intake,4 elec conduit straight back exhaust,KC stage 1 turbo,hd built auto tranny,pohp hydra chip custom tunes,still needs alot its work in progress.
  #12
Old 04-11-2017, 01:47 PM
psduser1's Avatar
psduser1 psduser1 is offline
Colonel
Member's Gallery
Default
Quote:
You and I can do that, but for a beginner, multipass is easier, lol.
__________________
2000 f250 zf6, air, oil, fuel mods, flatbed dual dana 80
Almost stock
2001 f250 same setup as the 2000, auto trans
2002 with a couple of mods, grocerygetter
  #13
Old 04-16-2017, 06:35 AM
ja_cain's Avatar
ja_cain ja_cain is offline
Colonel
Member's Gallery
Default
Joe is right about just butt welding thin walled tubing. The swagelok orbital welder does autogenous with a backside purge. Get a dual outlet regulator if you plan on doing a lot of stainless. Money well spent. I'll try to post up some pics of half purge and half no purge on some pipe to illustrate how bad the sugaring can be.
Stubby gas lens is also a good upgrade and I like the flex head torches from CK. I also have a nice water cooled swivel head from them too.
Also, stainless has lower thermal conductivity than steel. In other words, you want to make sure you aren't lingering or it will get too hot quick on thinner parts. I have a hard time with this sometimes. Male sure you know how to read your colors.
I use 2% lanthinated for both dc and ac welding. You can weld aluminum with it sharpened and a slightly balled tip on an inverter machine. Very versatile tungsten.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
