Who's replaced rear door lock actuators on crew cabs?
chaselee
I've got a pass rear actuator that has given up on me. Does anyone know what exact actuator works on these rear doors? My understanding is that the OEM part has been discontinued and that they were crazy expensive anyway. I've seen forums of people using foxbody mustang to crown Vic to bronco actuators. In all actuality id like the part number of someone that has done it and it has worked! Lol.
Also I found the darn thing which is way down in the door under the latch assembly. How in the world do you get it out of there!? I can barely get my hand on it, much less any tools or anything. Thanks!
Parker, TX
Sorry I don't have a part number for you. I bought mine off ebay and it was off some other Ford vehicle. The rod was different, but I used the one off my truck. You have to drill the large rivet out that holds it to the door on the edge. I used a bolt and lockwasher to put it back in. It was a chore to get back in there! That's not much help, I know. Cheers!
