Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #151
Old 09-20-2018, 08:50 AM
gotchadollar's Avatar
gotchadollar gotchadollar is offline
Sergeant
Member's Gallery
Default
Mine did a consistent 580-589 when I was still vgt.
Quote:
Originally Posted by Corys6.0 View Post
I’ve seen 600rwhp out of a hot tuned 15-16’. If that’s true. That’s amazing.
  #152
Old 09-20-2018, 09:42 PM
Corys6.0 Corys6.0 is offline
Sergeant
Member's Gallery
Default
Quote:
Stock turbo? What can the stock motor handle safely? 700rwhp?
  #153
Old 09-21-2018, 01:27 PM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
11-16 trucks can live at 700. i know of at least three 2017 trucks at 740ish and still ticking fine...
  #154
Old 09-21-2018, 01:44 PM
Sergeant
Member's Gallery
Default
Mines at 680-689hp
Buddy of mine, 2011 has done 720-730hp
  #155
Old 09-21-2018, 04:03 PM
sootie's Avatar
General
Member's Gallery
Default
Mines at 680-689hp
The 720 HP Non vgt I assume? These engines don't like those numbers with a vgt...
Sent from my SM-G955W using Tapatalk
  #156
Old 09-21-2018, 09:16 PM
Sergeant
Member's Gallery
Default
Correct sir
  #157
Old 09-22-2018, 03:52 AM
Sergeant
Member's Gallery
Default
Sounds like the motor is good at 700 does that go for the trans as well?
Is it true to stay away from the 11’s something about a valve issue? Anyone have an idea what these trucks weigh.... 4 door shortbed 4x4 Lariat.
  #158
Old 09-22-2018, 07:02 AM
sootie's Avatar
General
Member's Gallery
Default
Trans will live a long while at 650+. Mine makes 668 and has been thrashed daily for years now. I have a comp unit sitting on the floor so I've been trying to break it to no avail!
The valve issue on the 11s was isolated to trucks built before April 11 I believe. But yes it is a real thing as my truck had the problem and got a new/used heart as a result
  #159
Old 09-22-2018, 08:37 AM
Sergeant
Member's Gallery
Default
I lost my trans at 28,000. but my buddy has had his 2011 with stock trans at that power for 120,000 miles. Shows you the difference in those extra clutch packs I guess.
  #160
Old 02-08-2019, 05:05 PM
11KingRanch's Avatar
11KingRanch 11KingRanch is offline
Private
Member's Gallery
Default
Has anyone on here purchased the ‘15 retrofit kit with the modded 66mm streetmax x from Midwest?? If so what all is included in that kit?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Designed by Military Ltd
