#71
Price?
__________________
"Shamu" 1996 Cali F350 DRW CCFB, 7.3/E4OD, 2wd SAS w/ 392,000 miles, rebuilt at 352,250.
"Moby" 2018 F350 DRW, 6.7/6R140, 4wd w/ 34k miles |
#72
Sorry bout that, I was thinking 200. You can text me with questions and I can send pics 2623709135
#73
Does anyone have a pulley for sale?
#74
Does anyone know if a 1997 E350 7.3 pump and pulley would work for a conversion?
#75
__________________
'97 Black F250HD SC, 3.55s, Punisher Trans, PI Converter, Dana 60 RSK w/ V & C SD springs, PIS 175/80s, T500, Cale's tunes, 910s, Smith Bros, ARPs, Fluidampr, IC, E-Fuel, 3" Plenums, CJC Traction blocks, HFHV IDM, T4/BASB, Horton, 268K - 2016 F350 DRW Ultimate (stock for now ![]() - 1987 Buick Grand National (Staged) - 2004 Mercury Marauder - 1993 Geo Prizm (beater) |
#76
Seller took a while to ship the bracket but I finally have it. Pictures won’t upload but the part number is F7TE-19E708-BA.
#77
Also, I got the ps reservoir from a E-350 but not the cooler that it comes with. Is the cooler needed or can I just cap the inlet on the ps reservoir? Thanks!
#78
Haven't posted here in awhile. Just finished my power steering/hydroboost swap.
I originally was running the F-SuperDuty hydroboost unit along with the matching master. Although the truck stopped fine but the brake pedal feel was not correct. So I found a Ford F-53 Hydroboost unit and purchased the OBS F250/F350 master. The master is obsolete so I settled with a Raybestos unit. Since this going to require some custom hoses, I decided to swap the fittings to -6AN. Hydroboost unit: Aeroquip FBM2608 - 16mmx1.5 - 6AN Aeroquip FBM2609 - 18mmx1.5 - 6AN TechnaFit FTS 185009 5/16-24 o'ring Pump: TechnaFit FTS 306-06-M16DW 16mmx1.5 with Dowty Washer Gear (4 bolt cover) Russell 648010 1/2-20 -6AN o'ring seal I bend up some 3/8 stainless tubing and single flared the ends with tube nuts. I covered the power steering lines with silicone fire sleeve. I rotated the pump fluid inlet to a better position. The non-pressure hose is Parker Pusk-Lok hose with Fragola hose ends. The feed line is 3/4 (-12) and the return is 3/8 (-6). The return lines are "T'd" together (OEM tube cooler, hydroboost unit and reservoir) I forgot to grab a pic of how I mounted the Ford reservoir. The OEM reservoir has a build in screen for filtering. Also, I replaced the stock steering shaft with the Borgensen shaft. I'm eventually probably going to swap in a Blue Top gear. Since my truck has the 4 bolt cover, I want to find a core and send that one in so I don't have any down time. Didn't drive the truck yet, ran out of time. ![]() ![]() ![]() ![]() Billy T. gnxtc2@aol.com
__________________
#79
![]() Quote:
Mine is really stiff. Seems like steering is harder than it should be. I understand where a better pump might help, but I also understand why it might not or not last very long. My truck will certainly stop but but you are pushing hard. I was disappointed after the swap (and yes I moved the pin on the brake pedal) I do have a new steering box installed but not because of this fiasco. What rear brake setup do you have? I think my next step is possible hydroboost porting unless you tell me this is the way to go. |
#80
Which master did you use? The OBS one or the F-Superduty?
And yes my pedal was stiff also. Billy T. gnxtc2@aol.com
__________________
Thread Tools | |
Display Modes | |
