Go Back   PowerStrokeArmy > Non - Specific > Project Forum
Reply
Thread Tools Display Modes
  #1521
Old 05-16-2018, 10:57 AM
8WR_ZJ 8WR_ZJ is offline
Lieutenant
Member's Gallery
Default
Sweet. I guess I will have to get Instagram soon so I can keep up with ya'll
Sent from my SM-G965U using Tapatalk
__________________
2015 F-350 CCLB 4WD, S&B, GH SOTF, 4" FLOPRO, FUN SWITCH.
  #1522
Old 06-14-2018, 05:48 AM
MeTo MeTo is offline
Sergeant
Member's Gallery
Default
Damn!
The next time you work on it. You should throw some chairs and beer down and sell tickets.
__________________
97 F350 XL std cab, zf5, srw (converted), 4wd, 3.55s, stock rims/tires size & fresh rebuild
2 Donaldsons, 3" dp, ACs & Hydra w/PHP & 1023, DIY 60 gl tank w/6 gl sump, eFuel/Cat filters, T500, HV LPOP, Aeromotive RR, Auber instruments & IDM mod, KC Drop in SXE, boost fooler, RiffRaff bellowed up pipes, 6.0 IC & 3" plenums w/RiffRaff inserts
  #1523
Old 06-14-2018, 07:10 PM
shmoozer's Avatar
shmoozer shmoozer is offline
Major
Member's Gallery
Default
Vids not working for me
__________________
"I have 2 speeds, full throttle and reverse....even reverse is pretty fast" -South Mouth
  #1524
Old 06-14-2018, 11:46 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Quote:
Originally Posted by Cutting-Edge Diesel View Post
thanks for posting the video!
Dude! That sounds sooo much better! And smoother! That is crazy whatever was changed in the fuel delivery system to make a noticeable difference!
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
  #1525
Old 12-13-2018, 07:57 AM
Cutting-Edge Diesel's Avatar
Cutting-Edge Diesel Cutting-Edge Diesel is offline
Sponsor
Member's Gallery
Default
I havent stayed on this thread like I should have. Car have performed great finishing out the season other than loosing a set of clutches in the lenco. Having to play with the stall on the convertor. With the pump change we are making more power down low and its causing us to be too loose off the line. But we are planning on putting the car on a Mainline hub dyno this winter and doing some turbo testing as well as engine set up. Ill be sure and take video.
  #1526
Old 12-13-2018, 07:52 PM
General
Member's Gallery
Default
Oh dam.. that is going to be a tuff one to get in control of... insane power down low that is. Lol... can you change the cam profile or fuel delivery to pull back the hp/tq down low so it can hook up better or is that a weight/suspension/tire change?
__________________
  #1527
Old 12-14-2018, 08:08 AM
Sponsor
Member's Gallery
Default
Traction isn't a problem right now. Its fluid coupling with the convertor prior to lock up.
  #1528
Old 12-14-2018, 08:14 AM
General
Member's Gallery
Default
Oh... that slip... lol.. guess i should have known that when you said clutches... brain fart...
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
