Go Back   PowerStrokeArmy > Non - Specific > Welding & Fabrication Forum
Reply
Thread Tools Display Modes
  #21
Old 10-16-2016, 07:54 PM
Dirtclod's Avatar
Dirtclod Dirtclod is offline
Lieutenant
Member's Gallery
Default
What are your goals with buying a welding machine?
  #22
Old 10-20-2016, 03:25 PM
UpstateDieselGuy's Avatar
UpstateDieselGuy UpstateDieselGuy is offline
Lieutenant
Member's Gallery
Default
Smaller projects in the garage.
__________________
2015 F-350 Extended Cab Short Box Lariat; Tuxedo Black with Black Leather Interior; 8 1/2' Fisher MM2
  #23
Old 10-24-2016, 07:42 AM
m j m j is offline
Major
Member's Gallery
Default
Quote:
Originally Posted by 521turbo View Post
Lincoln MP 210 is an awesome welder. 110/220. also has the option for tig attachment, and ARC. You can fide them for around a grand.
that is a perfect example
Rated Output
120V: 100A/19.0/40%
230V: 200A/24V/25%
they dont even list a 60% duty cycle rating.
says 210 on the box but is more likely a 60 amp welder.
__________________
Quote:
Originally Posted by Chvyrkr
BTS transmissions have the absolute top of the line hard parts and clutches, in every single one.....every once in a while that somebody like Mike O or Charles gets a different piece, because they've broken his normal piece.
  #24
Old 10-27-2016, 08:06 AM
Sterling B.'s Avatar
Sterling B. Sterling B. is offline
Sergeant
Member's Gallery
Default
Quote:
Originally Posted by TRUBBS View Post
i have a millermatic 211 and really like it a lot. can be done either 110/220 and will do 035 wire
Another vote for the MM 211. I go it because I didn't have access to a 220 plug, but wanted the option to run on 220. I really wanted the 252, but without access to the power to run it, it would have been useless.
__________________
'00 F250 ECLB 4x4 315/75R16 Cooper STT Pro
F450 front and 350 DRW Springs w/ PMF front Shackles
370K miles and counting
DP Tuner: Stock, 40T, 60T, 80E; 6637 air filter
5" Flo-Pro, B&W Turnover Ball, Sinister coolant filter
ISSPRO EV2s (Pyro, Boost, Trans)
'15 F350 CCLB DRW... basically stock
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
