Tig or mig on upipes?
ford rules
I'm building a set of upipes using 304 stainless. What's your guys opinions on tig/mig. I can mig them myself but idk how they will hold up being stainless and using er70s6 wire.
kyle43335
If im repairing the factory junk T409 up pipes, i just mig them. when i build
(from scratch) T304 uppipes, i tig them. For what its worth.
ford rules
I'll be using pieces of the factory pipes. I think ill be fine miging them.
ford rules
I would tig them if I had a tig but I don't, I could find someone local but if mig will be fine I'd rather just mig them myself.
TurboM700
Minnesota
Mig will be just fine. Wont look as nice but will be plenty strong. Pickup a small roll of SS mig wire and use 100 argon if you CAN and you will be good to go.
Keep in mind I have welded plenty of SS pipe together with plan old shield mig wire with out any issues. Will rust over time but thats it.
ford rules
That's all I wanted to hear!!! I will try to get some SS wire and argon before the weekend if I have time.
I've done stainless before with plain old mig but never on something that will see high temps.
ford rules
Local welding shop recommended using 308 wire and 75/25. I thinkI'm gonna go that route and see how it works.
Jonnydime
I always used a tri mix when welding stainless. 90% Helium - 7.5% Argon - 2.5% Co2.
ford rules
I'll have to ask about that, our local shop just said use the 308 and 75/25 and I will be fine.
ford rules
Sounds good^ I'm thinking that .023 will be the wire size I should get. The upipes are 16 ga.
ford rules
Well I got some 308 .030 wire and it does pretty well I would say. I'm just using 75/25 still. I tried to use some .023 that I had found in the barn but it just wouldn't feed right, probably need to buy a .023 liner instead of trying to use our .035 liner.
I think the pipes will hold up well and they shouldn't rust as fast with the stainless wire.
ja_cain
I have always used a tri mix for gas when welding SS with mig.
Trimix is what you want. The 75/25 has too much co2 and will introduce too much carbon to the weld bead causing it to rust over time which is further accelerated by the extreme heat. The trimix is expensive though.
