Go Back   PowerStrokeArmy > Power Strokes > 94-97 Tech
Reply
Thread Tools Display Modes
  #1
Old 05-15-2018, 04:41 PM
Fletch1961 Fletch1961 is offline
Private
Member's Gallery
Default 96 7.3 LPOP symptoms
Motor has 105k on it. When cold (phoenix mind you) it starts right away then dies in seconds, will start again but sputter and struggle to stay running at idle. Once warmed up truck runs great. Let sit for couple hours then same issue again. Have changed the CPS, ICP, new fuel pump filter all motorcraft parts. No resolution. Could this be a symptom of the LPOP going bad, seem to remember reading this somewhere. Good fuel pressure but oil seems to lag about 5 seconds to come up.
  #2
Old 05-15-2018, 09:30 PM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
What is the oil level in the High pressure oil reservoir when it won’t start?
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, Garrett GT4294, Beans IDM, ARP head & main, girdle, half filled block, DI cam, Dual IPRs, ceramic coated bowls, anti-friction skirts, Haldex pump over Honey Badger Jr, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #3
Old 05-16-2018, 10:19 AM
Private
Member's Gallery
Default
The oil in hpop is low. The problem is not it wont start, it starts everytime. It just starts then dies after a couple seconds. Then after 3rd time it stays running but sputters for a couple minutes and finally smooths out and runs great. Almost seems the oil is draining back out after sitting then when starts, hpop runs out because lpop is trying to fill it. I am thinking might be wear in lpop enough to cause the issue. Problem is it does not do it everytime, maybe every couple days or so.
I think I am going to just change the lpop out with a melling unit. Have heard good reviews on them.
Will let you know if that does the trick.
  #4
Old 05-16-2018, 11:30 AM
jschildm's Avatar
jschildm jschildm is offline
Sergeant
Member's Gallery
Default
Could be draining out of the HPOP. It seems like the LPOP is potentially doing its job if you crank a few times and then it stays running and is fine until it sits a while.
__________________
1997 F350 CCLB, 3" DP to 5" Straight Pipe, DIY Intake, 6.0 Tranny Cooler,Adrenaline, Irate Electric Fuel, Matt's Tunes and SD Seats ... IC and H2E sitting in the garage.
  #5
Old 05-16-2018, 01:30 PM
Magnum PD's Avatar
General
Member's Gallery
Default
If there is wear on the gears, it can be a problem.
Look at last page:
http://powerstrokearmy.com/forums/at...9&d=1307148441
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
