Go Back   PowerStrokeArmy > Power Strokes > 7.3 Tech
Reply
Thread Tools Display Modes
  #11
Old 06-29-2020, 07:22 AM
19.5s's Avatar
19.5s 19.5s is offline
Private
Member's Gallery
Default
I had a similar problem with mine except it was a cold-start problem and shimming the injectors worked. At the same time, i did have a battery issue too. I took the batteries to O'Reillys twice to have them checked out and they said they tested fine even though they would not turn the truck over but 1 revolution. Long story short, I replaced the batteries with AGM batteries from the same place and the truck turned over fine.
I have had experiences with large inch/high compression V-twin bikes not engaging the starter due to low amperage in the battery even though it measured 12 volts.
The 2 things I would look at are your starter solenoid and batteries, regardless if they are new or not. If a solenoid is out, you wont hear the starter gear engaging the flywheel. If it is batteries, the starter gear might engage but not have the amperage to turn the truck over.
__________________
2004 F550 with 2000 7.3, Forged. 205/80 FFD injectors, S&B intake, Diamond Eye 4" exhaust. 1023 Tuning. Stock Tranny, Stock Turbo (for now) KC300X66/73 coming soon. Pioneer, Kicker, and Memphis audio system with back-up camera.
  #12
Old 07-02-2020, 07:47 PM
TjMiller's Avatar
TjMiller TjMiller is offline
Sergeant
Member's Gallery
Default
Jump the starter out and check the voltage drop - that should give you a clue. Post a video
__________________
09 F350 6.4 SCLB ******* 210
92 ? E150 body/E350 frame Sterling 10.5 rear axle/D60 front 7.3 under construction
  #13
Old 07-03-2020, 07:05 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
So the starter engages but doesn't turn the flywheel? Or it just clicks? Either it is hydro locked or you dont have enough amperage to spin it over.
live life full throttle
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
