6.4l aftermarket and stock parts
Sahrens0202
OH,WY,ND,CO
RCD stainless cold side pipe with BOV bung and (3) bungs for Nos or whatever; $150 shipped. I think the BOV bung part is steel.
BD diesel BOV with controller; $625 shipped. Has some rubbed areas on the one side but does not affect operation.
Factory 6.4L intake manifold; $50 plus shipping, no threads are stripped, other than some carbon/oil on the inside it's in perfect shape.
12" long x 4.5" polished tip, I believe it's meant to clamp to a 3.5" pipe and does have a few scratches. $40 shipped.
No limit 6.4L egr removal kit WITHOUT COOLANT PLUGS, comes with everything in the picture. $180 shipped.
6.4L factory turbo's with minimal shaft play, 150K miles. Took them off when I replaced my up pipes and did a single install. The oil drain pipe is bent and one heat shield bolt in the back snapped off but everything else is in good shape. Comes with pedestal, bolts, heat shield and coolant tubes if you want them. $350+ shipping
RCD pipe, No Limit kit and BD BOV for $800 shipped.
Sahrens0202
OH,WY,ND,CO
AD, Fuel bowl ******, Banks 6.4l CAI, BOV ect
Bumping this up. Wheels on truck in avitar, '08 duelly. Fuel Mavericks, 20" with Toyo ATII extremes, 10% tread left. Normal rock chips and surface scratches. $1,000 located in Laramie WY. Make frequent runs to OH, CO, ND so possible deliver, meet somewhere along the way.
Also have this http://powerstrokearmy.com/forums/showthread.php?t=67302
!!!!New prices!!!!
Stainless tip $20 shipped
Intake manifold $40 shipped
RCD cold side, BOV w/ controller and No Limit egr D2lete $750 shipped.
Banks 6.4l CAI with 2 filters $100 shipped
6.4l turbos $300+ shipping
Factory egr coolers $50 shipped(heavy)
Icon 2.5 piggyback fronts and 2.0 rears(v.s. series) for 4.5" lift, 05 to '10 superduty. All need rebuilt, rears might need new shafts. Bodies in good shape. $400 shipped
rt-hemiboy
SFL
Question any benefit on running the pipe with thre bov if so can you explain and do i need anithing else extra to put it and run it on my truck thansk??
Sahrens0202
OH,WY,ND,CO
Cold pipe get's rid of the pinched factory one, free'er flowing. The BOV quickly release boost when you let off the throttle preventing turbo stall from high boost and possible damage.
Sootie is correct, the powerstroke and 6.7 badge are seperate, 4 pcs.
Vanarsdale06
I'm interested in the turbos, how much for shipping to 46052?
mikegt94
Do the turbos were whining? I not i am interested
Enviado desde mi SM-N950F mediante Tapatalk
