Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #21
Old 07-11-2018, 08:26 AM
ToMang07's Avatar
ToMang07 ToMang07 is offline
General
Member's Gallery
Default
Fluid level good and all the air out of the lines?
__________________
~Tom~ 02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, Hydra, 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, T500, FRx, COMP 910s, Fisher 8' MM2, 5" AL 1-piece Drive Shaft, Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, Hutch/Harpoon, RR-Plenums/clamps, 203* TS and Billet Housing, ELC, Fumoto, Leveled, Airlift Bags, 16x10" on 35s, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing... Rebuilt Transmission at 137k~AE w/Ford Pack~
  #22
Old 07-11-2018, 09:41 AM
kcstreetracer's Avatar
kcstreetracer kcstreetracer is offline
Private
Member's Gallery
Default
Quote:
Fluid level is good. I don't know about air in the lines. How do I check that?
Sent from my Pixel 2 XL using Tapatalk
__________________
2012 F250 SC | 12" FABTECH LIFT | 40x15.5 NITTO MUD GRAPPLERS | 20X12 FUEL MAVERICKS | NFAB STEPS | *** & EGR ******D | 5" AFE DP BACK EXHAUST | S&B CAI | AFE HOT & COLD SIDE | PCV REROUTE | LONGHORN TRACTION BARS | SCT LIVEWIRE W/ TUNES FROM TYRANT
  #23
Private
Member's Gallery
Default
Quote:
Originally Posted by Mhatlen View Post
Is it slipping on shifts through the gears with power or skipping?
Yes a bit of both
__________________
  #24
Old 07-12-2018, 10:27 AM
BigRed97's Avatar
BigRed97 BigRed97 is offline
Sergeant
Member's Gallery
Default
Try doing a adaptive reset
__________________
Truckless for now
  #25
Old 07-12-2018, 12:56 PM
blacksmoke.r.us's Avatar
blacksmoke.r.us blacksmoke.r.us is offline
Sergeant
Member's Gallery
Default
I lost all the fluid in my trans one time and it took a lot of driving to purge the sytem fully. I also thought I blew my trans.
When in drive the trans would go automatically in to 5th but I had reverse. I drove around in reverse to purge the system of air and heat up the fluid. Finally as the trans got some heat in it, it started to shift in drive, still erractic but better. After I got a few foward gears I got some more heat in it and the more I drove it the better it got and soon after it was normal. Shifting threw all the gears like it should.
I think the trans has to be at a normal operating temp to open up the all the valves in the valve body. Then you will be able to purge the system fully.
Remember to keep adding fluid as the trans purges the air, just try and not overfill. Also when doing this dont abuse it as it could lead to some other issues
  #26
Old 07-12-2018, 02:32 PM
Private
Member's Gallery
Default
It's at Ford getting diagnosed. Of course their saying burnt clutches. They probably are knowing my luck. It's been driven a few hundred miles, I would think the air is worked out by now
__________________
  #27
Old 07-12-2018, 04:36 PM
doo dah's Avatar
doo dah doo dah is offline
Sergeant
Member's Gallery
Default
I have a Suncoast 750hp kit in mine. Also got their torque converter and billet flexplate with the kit. My truck has 575 & 1100 at the wheels so way more than I need but I can beat on it and not worry about it. Mine was pulled and rebuilt, if you are going to swap Midwest might be a better option.
__________________
2012 F350 CC LB 4x4 Lariat. MiniMaxx with TSD tunes, 5" exhaust, Industrial Injection S363 single turbo kit.
  #28
Old 07-21-2018, 11:40 AM
Mhatlen's Avatar
Mhatlen Mhatlen is offline
Corporal
Member's Gallery
Default
So how did it play out ? Did you loose some gears in your transmission?
__________________
2006 LARIAT F250 CCSB 4X4, Edge CS2, ARP 625 Studs, O-Ringed heads, KC Turbo S1 Custom w/ AR.72 compressor hsg. 10 Vane, Cat EC1 Coolant, IPR Coolant Filter, Fass 125 w/ 5/8 p/u tube & 1/2 output to upper fuel bowl. A 2003 ECM Rollback- X4 PHP 65 HP Custom Tow Tune, Atlas40, SS 4 turbo back, SS & Diamond Eye Muffler, Intercooler upgrade 3 CAC Pipes. 6.4 Starter, DC Power 270XP riding on 7" lift on Icon coils, Carli/Deaver 2008 leaf springs riding on fatty daddy 38/15.50/18 Toyo's
  #29
Old 07-24-2018, 02:45 PM
BIG JUICE's Avatar
BIG JUICE BIG JUICE is offline
Lieutenant
Member's Gallery
Default
What they say?
__________________
2015 F250 platinum, flopro 5", jones turbine 5050xl, polished No Limit stage 2/pg 7 and prefilter intake, h&s intercooler pipe(throttlebody-gone) and half ccv reroute, jenny craig, sotf gear hedd tune, Rigid DOT fogs, Chinese 40" radius led, amp steps, weathertechs, edge cts2, titan tank, dieselsite fuel filter, blue ox gooseneck, Hellwig bars, retrofit projectors, linex plat, retrax cover,full Carli 2.5" backcountry,fox 2.0 res shocks, toyo rt 37", OUO ala & bars
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
