Differential covers?
Quigs4u
I called ATS they don't have any diff covers available yet for our trucks. I was told soon but nothing yet. I'm Waiting for a call back from Mag Hytec. Has anyone replaced the stock covers yet ? Do any manufacturers make them yet?
Central Illinois
I would definitely make sure what axle you have. You did not mention if you have a F250 (Sterling 10.5), F250HD package (Dana M275), F350 SRW (Dana M275), or F350 DRW (Dana 300). There are 3 different axles now depending on which one you have and unless you have the regular F250 without the HD package, non of the other ones have the old Sterling 10.5 rear end. Heres a quick description of the new axles.
"The release of the 2017 SuperDuty brought about some revisions to the axles in order to support the additional power and towing capacity compared to the previous 2011-2016 model year generation. Up front, its basically unchanged with the use of a 35 spline Super Dana 60. Out back, however, there are several variations depending on the capacity of the truck. For those with an F-250, you'll be sporting a similar Sterling 10.5 that has been used for years, still featuring a 10.5" ring gear. Moving from there, the F-350 Single Rear Wheel (SRW) models get a Dana M275 with a 10.8" ring gear and the F-350 Dual Rear Wheel (DRW) versions are bumped to a Dana M300 with a massive 11.8" ring gear. The 10.5" has 35 spline axles, where the M275 has 36 splines, and the M300 boasts 37 splines. "
Quigs4u
Great info thanks!
It's SRW 350 so it must be the Dana m275 in the rear
As for the front it's the Dana 60 so I should have no issues ordering the front cover it's the rear that's the problem.
Central Illinois
Great info thanks!
No problem! Yup, youll definitely have the Dana M275 axle then. And like you said the front shouldnt be changed. Good luck with your search!
Quigs4u
Let me reach out to him. Thank you
I'll keep you posted
Quigs4u
I'm pretty sure Trevor with PMF does have covers available for the new m275 axle.
Thanks!! I got this from PMF so I wanted to share it with the group. It is available and it's list price is $229.00. I'll be ordering it shortly and will post pics when it's installed.
This info is directly from pmf's site
http://www.pmfsuspension.com/2017-HD-Fabricated-Superduty-Dana-14-Bolt-Rear-Diff-Cover_p_176.html
2017 HD Fabricated Superduty Dana 14 Bolt Rear Diff Cover
Part Number PMF-COV-9003
These covers are for single rear wheel 2017 Superduty axles with 14 bolt covers. These are typically found on the SRW F350 models.
bigrpowr
<How I Fly
Administrator
hit me up , we offer a forum discount !
