2002 excursion diesel tank options
greekman
I am trying to put togeather a kit to install on my 2002 excursion and am fashoning it after the golden system but 1300 for the diesel tank is cost prohibitive at this point was wondering if anyone else has found a replacement tank that will fit under the SUV between the rails to use as the diesel tank as I will be converting the main tank to svo and on that note anyone know the size hotfox to stick in the tank for svo the biggest you can fit live in international falls mn so it gets cold
thanks in advance
steven
fordman2121
huntington, in
I made an auxiliary tank using an old lp forklift tank. Just welded on some flat steel and I made it to where I only had to drill one hole in the frame. Ran a one inch hose up into the engine compartment and fill from there.
