351w Single Turbo will sell with/without turbo kit
cwienk
Hey all i know this isnt powerstroke related. So if it is forbidden admins feel free to delete. However it IS Ford related, and turbo and cool :)
I have a single turbo 351w for sale. I am located in South florida. I AM A MOTIVATED SELLER
1969 351w .030 357ci
5.956" 4130 h-beam rods
probe pistons 12358-030
scat crank
molly rings
main girdle
melling oil pump and pickup
predator custom turbo cam 1.08 bc dur. .050 int 230 ex 226 gross lift int 563 ex 560
roller lifters
balancer pro products
Heavily Ported pro comp alum CASTINGS ONLY 210cc
Manley/Ferrea valvetrain2.02 1.60 ss valves/ daul spring
intake prof products hurricane victor clone
injectors precision 95lbs low imped.
head studs
75mm throttle body
fox body oil pan powder coated gray intake also coated gray
Turbo Kit
motorsport headers flipped coated for high temp
2.5" merge pipe with flex joint also temp coated
t6 flange
bw s475 turbo
5" exhaust v band
3" comp outlet
tial 44 mm wastegate
50mm blow off valve
5" downpipe exit pass side
Air to water Intercooler assembly (intercooler mounts in windshielf cowl)
3" 90 degree rubber elbows (2)
all intake piping
2-8 an line assemblies cooler to water tank
3 gal jaz prostock fuel cell
flojet 12v water pump/ ball valve for drain
I am going to throw a number out and say $6500 complete for everything, i am located in south florida. Will accept offers. Not looking for any trade except possible a dart block. phone is 239-438-0110
Stangr8cr
5.70's in a 3200lb car is normally around mid 900hp range, maybe a touch more. That's a pretty heavy car by drag racing standards.
Keith
slowcoupe
Las Vegas, NV
How many passes are on this motor setup? Could you post some pictures of the interior setup you have for the intercooler. Id like to drop this into my 92 notch but would need a front mount so I'd have to change a few things obviously. My car is still a street car.
