Transmission help
09strokerpwr
oshkosh, wi
So back story is I had a stage 3 trans from Rudy's diesel. Tuned by ******* sotf. Put 40000 on trans without a problem. Last fall was driving my truck and when the converter locked it let go. So took to a local shop and found that the billet input shaft was snapped, toasted the converter. So he built me a new trans with better shaft new precision converter and clutch packs. So after getting truck back I took it easy on trans for bout 600 miles. Then one night driving I went to pass a car with the converter locked up. Something felt off could feel a vibration and seemed low on power. Soon as I let up on throttle went away. So on next stright away I gave it again and same thing. I monitor torque converter slip on dash daq and seen the number spike all the way up to 700rpm. Took the truck back to trans shop showed him what was happening. He took the trans out went threw it and got a new converter. Only to have same problem. Truck has now been there almost weekly since December. He has replaced torque converter 4 times tried different brand this last time. New value body, all new solenoids, 3 different pumps. 1 used working and 1 new from Ford. All new pressure switches, springs and even a brand new tcm. I have tried returning truck to stock and redoing tunes only to have some results. I'm starting to run out of patience and he is running out of ideas. So far this hasn't costed me a dime besides the inconvenience of dropping truck off Sunday nights and picking up Friday night and getting rides to and from. Other then the converter not holding under lock up with a load on it trans shifts and works great. Open to ideas or suggestions. Thanks
EPA
Maybe wrong fluid... Could low line pressure cause this? Maybe cooler is all clogged... Maybe a contaminated cooler is causing the new tc to fail. I have no clue these are some ideas... Hopefully some other members chime in soon.
Lipka101
Maryland
Who’s tunes? I had similar issues with GH tunes after I built mine. I ended up running tyrants tunes.
Sent from my iPhone using Tapatalk Pro
09strokerpwr
oshkosh, wi
S p a rtan. I never had a issue with the other built trans. He even swapped a stock one in this week and tuned for a stock trans with same results.
White_monster
The great white north
If it's doing the same thing with two different transmissions and different tunes I'd start looking at other components. Axle wrap maybe, usually only notice it on take off though.
EPA
How would this cause the tc to slip 700rpm when locked up?
09strokerpwr
oshkosh, wi
You can make it slip under load watch it on the gauge let off just a bit and feel it grab and drop back down to no rpm slip
I would look into the wiring harness that goes from the ECU to the TCM. Inspect the whole thing ohm out all the wires.
This is a long shot but on the 6.0 the electronic cooling fan clutch shares the same power supply as the transmission sensors/power. When the electronic fan clutch shorts out it causes transmission problems. The TCM might share the same VBPWR as the fan clutch. Can you unplug the fan clutch and see if the problem goes away?
Thanks
