Go Back   PowerStrokeArmy > Power Strokes > 6.7 Tech
Reply
Thread Tools Display Modes
  #1
Old 01-12-2018, 03:03 PM
Texan6Seven Texan6Seven is offline
Corporal
Member's Gallery
Default 30 minute serpentine belt R/R without removing fan.
It can be done for those not wanting to buy the extra tools to remove the fan. I removed the old belt without cutting that either. If you remove the bolt holding the fan clutch wire harness bracket and disconnect both ends of said harness itís free to rotate towards the fan allowing you to slip the belt over one fan blade then rotate the fan around and the belt slips off. Installation is in the reverse order. Check that the belt is routed in the proper orientation and reinstall the fan clutch bracket and harness. Just thought this may help some folks on here.
  #2
Old 01-12-2018, 04:16 PM
Sportchassis06's Avatar
Sportchassis06 Sportchassis06 is offline
Lieutenant
Member's Gallery
Default
Quote:
Originally Posted by Texan6Seven View Post
It can be done for those not wanting to buy the extra tools to remove the fan. I removed the old belt without cutting that either. If you remove the bolt holding the fan clutch wire harness bracket and disconnect both ends of said harness it’s free to rotate towards the fan allowing you to slip the belt over one fan blade then rotate the fan around and the belt slips off. Installation is in the reverse order. Check that the belt is routed in the proper orientation and reinstall the fan clutch bracket and harness. Just thought this may help some folks on here.
I never had to slip the belt over the fan,I just remove the bolt connecting the fan cluth harness.And remove the belt??
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
