Go Back   PowerStrokeArmy > The Bunker > General Discussion Forum
Reply
Thread Tools Display Modes
  #1
Old 03-09-2018, 10:36 PM
CTC DEEZUL's Avatar
CTC DEEZUL CTC DEEZUL is offline
General
Member's Gallery
Default VP44 performance
Need to discuss some performance expectations out of a 01 DUDGE. I hate working on these things as I'm not 100% on them.
Truck has performance injectors, assume 100hp, after market injection pump, 7 level edge tuner. It's got all the fuel it can handle, I'm trying to get the guy to go with a new charger to help clean up the smoke and actually put some power to the ground.
It's a rebuilt trans and i can bet it's a stock rebuild.
You can't do a brake torque if your life depended on it, actually, 1st gear is just all smoke and kinda low on power, 2nd is ok, it's bet to roll into and not just stab it.
Shouldn't this thing be a bit more powerful? Looks like there is a j hook on turbo as well... Kinda telling the guy his trans just isn't taking it and that's the issue, but stock turbo isn't helping.
The trans got up to 200F just beating it around the block which I think is insane.. says it overheats when he plows too...
Advice?
__________________
Teamsters Local 444- Rolling Coal United
  #2
Old 03-09-2018, 11:15 PM
ghohouston's Avatar
ghohouston ghohouston is offline
Colonel
Member's Gallery
Default
The few I've worked on had great power. Does he have a lift pump? J hook on the turbo???
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2011 International Duraturd 4300 Mechanics truck
2001Tdi Jetta 5 speed
  #3
Old 03-10-2018, 12:27 AM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Yes it's got plenty of fuel, FASS system.
J hook holds waste gate shut
__________________
  #4
Old 03-10-2018, 06:22 AM
6.0 Tech's Avatar
6.0 Tech 6.0 Tech is offline
Colonel
Member's Gallery
Default
Actually ran into this with a buddys truck. Buddys was a common rail though. Are there any codes, specifically cmp/ckp correllation or anything like that? His cam retainer was worn, causing it to push out of the tone wheel pick up basically. Sometimes it would run like a raped ape, sometimes it was a slow turd. He finally welded a nut to the front cover to push the cam back, as that seems to be what the $100 repair kits are, except aluminum, and never had an issue again.
__________________
04 cclb IDP and TSD tunes, KC Stage 2 hi pressure, S476 atmosphere, Odawg Stage 2 ported intake, RCD Stage 1 cam, RCD lifters and pushrods, RCD 120# valve springs, ARP 625s, o ringed heads, Warren 7mm 250/100 hybrids, Strictly bowl dereete regulated return, Air Dog 2 4g, Snow stage 2 water/meth
  #5
Old 03-10-2018, 06:42 AM
gwunter's Avatar
gwunter gwunter is offline
Lieutenant
Member's Gallery
Default
I would think that combo would be right near 450hp. Ibe got a friend who has a similar setup but with a silver 62 and he put down 550 on the dyno. And he has a built trans by "dans transmission" over in gas city....or somewhere in the east side of state. What vp is he running?
__________________
Just a crazy, wannabe machinist....making crazy stroker parts.
  #6
Old 03-10-2018, 06:53 AM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Post the question on Comp D
  #7
Old 03-10-2018, 07:55 AM
gotchadollar's Avatar
gotchadollar gotchadollar is offline
Sergeant
Member's Gallery
Default
Truck will not power brake because of torque management. It will only allow a certain rpm. A smarty is the only thing to turn it off.
__________________
2015 6.7, 20x12 Sota BRAWLS Wrapped with 285/55/20 Nitto Terra Grappler G2s, EZ Link w/DarksideCals, HS-Motorsports 64.5 Sxe Kit, Dual Fueler, Low Pressure Pump, No Limit EGR, Intake, Suncoast 1900 stall convertor. Randys Transmission.
689Hp-Custom Auto UCC Dyno
  #8
Old 03-10-2018, 05:15 PM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Quote:
Oh really?
How's it controlling it? The torque management that is
__________________
  #9
Old 03-10-2018, 06:28 PM
Sergeant
Member's Gallery
Default
Through the ECM, I do not think there is a bypass for the torque management. At least I never found one on my 24v. Soon as I put a smarty on I was able to turn it off
Quote:
Originally Posted by CTC DEEZUL View Post
Oh really?
__________________
  #10
Old 03-10-2018, 06:39 PM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Hmm not ****. This guy has all edge tuning and a edge box. I mentioned going with smarty, but then he's lose his shift.on then fly ability
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
