chrome wheel care
05wh250
hendersonville, nc
What is everyone using to help protect their chrome wheels? Always heard use wax but wasn't sure if there was something better.
weazel
Elkview WV
I powder coat them black, boom done
Sent from in a ditch up side down and on fire with the wheels still spinning
Dzchey21
wyoming
Whack answer...
I like to use never dull about every other car wash, it's easy to use and it really seams to protect the wheels between washes. It is like a balled up cloth in a metal can, a little goes along way with the stuff, it will also take any rust off the chrome and shine it up like it was never there, i had a couple center caps i was worried about but it shined right up and the rust hasnt been back. I just washed my truck the other day and didnt have time to polish the wheel again but they looked almost as good as when i do polish with just pressure washer no scrubbing brush or anything. Really happy with the stuff
05wh250
hendersonville, nc
Yeah I've used never dull before, just wasn't sure if i could do anything before the tires get put on to protect them. Never thought about using never dull like that though, have to try it.
05wh250
hendersonville, nc
Im more asking if theres something i can seal them with to protect them from the weather before i put em on the truck. Kind of like wax on paint helps protect it from the elements but for chrome.
Dzchey21
wyoming
ahhhhhhh my bad
I use a spray wax on mine in the summer seams to work well, if the water wont touch it neither will the elements.
I might continue using the never dull, it sure seams to have the same effect.
fine69
Cranberry Twp,PA
I wax the front and back sides of my wheels with Mothers Carnuba Gold every spring before I put my wheels on after winter. Another good tip, to prevent my stick on wheel weights from falling off, I coat them in clear silicone RTV. Just be sure to go all around the weight sealing it to the wheel. It's not heavy enough to effect the balance and it will scrape right off if you nedd to re-balance for some reason.
05wh250
hendersonville, nc
Thats a good tip i was wondering about those stick on ones
Purdue_stroker
Ladoga, IN
I use meguiars hot chrome wheel spray. It is awesome!! Just spray it on and hose it off, or spray it on right before you go through the wash. It will peel caked on brake dust right off no prob and your wheels will look brand new. It's in a see through red spray bottle at autozone or Walmart
