My 6.0 into OBS project
theNewb2003
Well after doing alot of searching, and coming up with very little info if any at all. I've decided to start a new thread.
I have a 1995 F250 that was a gasser, motor was bad but body and bed are straight. I purchased a wrecked 2003 f350 superduty with a 6.0 and 6spd MT. The transmission was less then two weeks old when pickup was wrecked, and motor had been bullet proofed. Yes I'm sticking ford with ford, if I wanted another dodge I would go buy another dodge...
So here are some nm picture just to get this thread started.
Sent from my SM-G892A using Tapatalk
theNewb2003
Then there is this mess Haha
Dont forget about all this eather
Lt.Dan
Visalia, CA
Theres another guy doing this on PSN. Hes putting an OBS cab on an 05 frame though w/ a 6.0 in it.
theNewb2003
Yea I seen that, he was modding the firewall and stuff. As it is right now the only modification I have to do is finish building my motor mounts. Granted I still have a ways to go but. Transmission mountain right up no modifications to cross member or anything so.
theNewb2003
Ok, so as after spending most of the afternoon looking at motor mounts I accomplished nothing haha. Did get the steering box from the super duty mounted on the obs chassis. Surprisingly everything again bolted up. Did have some concern on how I was going to set up the hydro boost but with the steering box bolted up everything is good to go on that front. Will be mounting hydro boost and pedals tomorrow after finishing motor mount. More pictures tomorrow
theNewb2003
Ok update, motor is in. I ended up using the transmission mount from the 03 sd. The mount for the 1995 had the transfer case sitting to close to the driver side frame rail. I will be using the 03 gauge cluster and mounting it into the 1995 dash. There will be some modifications that I will have to do to the outer dash peice for the 1995. Will be starting on wiring tonight.... more pictures to come
