05 + track bar
Diesel_Brad
Gilbert PA
What has everyone been using for a track bar mount for the 05+ axle?
I think I may have found a BOLT in one depending on where the track bar has to go
FrankTheTank
Cecil County, MD
Usually right below the rear most power steering bolt, slightly forward is still ok. And should drop about 3" to center below the botton of the frame.
What do you got, I know Quigley has a bolt on bracket
mxtwo50r
I used most of a 6" pro comp 05-07 track bar drop bracket. I will try and find a pic. I'd love to find one that is more of a bolt on application that I could modify for mine being lifted. Mine is in just needs to be finish welded, but debating on going a different route.
Only pic I have currently is from when we were mocking it up and doesn't show much
Ended up working out ok, Still kicking around in my head if I want to keep it as is or change it up before I call it 100% done.
Interested to see some other setups or ideas on this topic.
mxtwo50r
Bumppppppp
Any lifted 05+ swapped trucks want to share their track bar mount ideas? Interested to see the bolt on Quigley unit. I keep going back and forth on how I want to do mine. I see a modified rize industries one looks rather nice, not sure on the required modifications to it.
