Midwest Transmission Full billet 5R110
Jonnydime
This is the transmission out of my Harley truck. Can be purchased three ways. First is as is with the torque converter needing to rebuilt and needing an input shaft $3500. Second with a new aermet input shaft and no converter $4k and last new input shaft and rebuilt converter $4500. The first option will diaaspear once I ship the converter to be rebuilt. All prices do not include shipping from Clearwater, FL
Jonnydime
Trans will most likely be going back to Dan for tear down and inspection. Price will go up upon its return.
Extended Power
If the torque converter needs a rebuild, wouldn't the transmission as well? (They share the same oil)
Jonnydime
The way the input shaft broke in the converter required it to be cut open. It’s on its way to precision as we speak. The trans is heading back to Dan on Monday.
Jonnydime
The RCD converter has been rebuilt and will be here today. When Dan tore the trans apart they didn't find anything so the trans was good. They did notice the 2nd and 4th gear clutch packs had more wear than the others so they are replacing those. New aermet input rebuilt converter fresh trans $6k plus shipping
