Lowering a 6.0, misc questions inside
MrOneEyedBoh
Few questions: will running a 4800# spring and a 1" block be level or have the rear end just a tad higher?
Does running a 12" wide actually cause more wear on the hub's versus running a 10"?
What has to be trimmed usually n a 12" wide? What's rubbing?
as i said before, it will be level and have no rake-possibly be ass low.
yes a 12 wide is harder on wheel bearings, power steering etc.
fender liner and pinch weld will have to be trimmed. the tire hits the body when turning.
imelmo
This is 4000# springs and no block:
MrOneEyedBoh
I already bought 4800s. I was about to say lol looks ass high, but the lighter spring makes sense.
also the weight of the vehicle makes a difference. a reg cab short bed will sit different than a cclb
why not lower the front first, without touching the rear. Then take measurements and figure out what block you need for the look you want. simple.
MrOneEyedBoh
Lol true... Any idea on the sag, like say it measures 40" will it drop another 1-2"¿?
imelmo
This is the part number: 5C3Z-5310-HA
It's actually for a 2012 with the 6.2L gas engine. And it is Code X, 4000lbs.
Denotes the weight capacity
Sent from my SM-G935W8 using Tapatalk
