Go Back   PowerStrokeArmy > The Bunker > General Discussion Forum
Reply
Thread Tools Display Modes
  #1
Old 07-11-2018, 08:20 AM
ToMang07's Avatar
ToMang07 ToMang07 is offline
General
Member's Gallery
Default Anyone here mess around with the newer SHOs?
Just curious, lots of Ford guys on here.
Been drooling over the newer ones since they came out in 2010, that ecoboost engine is a beast. (Only downfall of the ford v6 motors is the retarded waterpump design)
Found a low mileage 2013 SHO for sale, modded out with cat-less DPs, upgraded CAC pipes, SCT X4, exhaust/intake, and a stage 3 meth kit.
Car is absolutely mint from the pics. Headed to go look at it and probably pick it up Friday.
__________________
~Tom~ 02 F350 CCSB 4x4 SRW 7.3L, DIY-6637, Hydra, 4" TB-409SS MBRP, GS 3 in 1, EGT/Boost/Tranny, T500, FRx, COMP 910s, Fisher 8' MM2, 5" AL 1-piece Drive Shaft, Tymar HPX, NON-EBV Pedestal, Turbo Master, Wicked Wheel, Hutch/Harpoon, RR-Plenums/clamps, 203* TS and Billet Housing, ELC, Fumoto, Leveled, Airlift Bags, 16x10" on 35s, CCV Dumped, Foil, AIH, and EBV, Pontoons All Missing... Rebuilt Transmission at 137k~AE w/Ford Pack~
  #2
Old 07-11-2018, 09:33 AM
8WR_ZJ 8WR_ZJ is offline
Lieutenant
Member's Gallery
Default
You will not regret getting it. Those motors are great. We have a client that have about 25 in their fleet of f150s. Most have over 200k with a few tapping 350k. All 13 and 14 model trucks. We did some tune testing with ppei at their place and truck made about 8 hp less than when it left the factory and that truck is the 350k ones. I know you were asking about the SHO just thought i woukd give some insight on the 3.5 EcoBoost engine.
Sent from my SM-G965U using Tapatalk
__________________
2015 F-350 CCLB 4WD, S&B, GH SOTF, 4" FLOPRO, FUN SWITCH.
  #3
Old 07-11-2018, 09:49 AM
ToMang07's Avatar
General
Member's Gallery
Default
My only issue with it is the waterpump design....INTERNAL timing chain driven. IF it lets go, it's a $2,000+ service and there's the possibility that it takes out your engine if you don't catch it. I'll be checking this sucker pretty regularly, lol
__________________
  #4
Old 07-11-2018, 01:37 PM
79jasper's Avatar
79jasper 79jasper is offline
Colonel
Member's Gallery
Default
I wouldn't exactly consider that a issue or point to not buy one.
Plenty of engines have been running that design for quite some time. Especially the vw diesels. Can't say I've heard of one just letting go.
Sent from my SM-G892A using Tapatalk
__________________
2003 F250 KR SCSB FX4
Depleted, studded, airdog (which isn't currently hooked up), fass regulated return, airaide, 4 inch straight pipe with mbrp muffler(so on to go), glowchit pyro, fuel, boost, and trans temp. (Of course don't work lol) Hercules terra track A/T2 315/70/17.
2013 Honda pilot Touring
http://badges.fuelly.com/images/sig-us/778639.png
http://badges.fuelly.com/images/sig-us/776628.png
  #5
Old 07-11-2018, 08:16 PM
6.0 Tech's Avatar
6.0 Tech 6.0 Tech is offline
Colonel
Member's Gallery
Default
Quote:
They typically do not dump coolant into the motor. There is an external drain hole that they leak out of right above the a.c. compressor. We dont seem to jave too many issues with them. The occasional turbo, water pumps, seem to happen most in the summer, and front cover leaks. The real fragile part is the ptu. Those seem to be made of glass.
__________________
04 cclb IDP and TSD tunes, KC Stage 2 hi pressure, S476 atmosphere, Odawg Stage 2 ported intake, RCD Stage 1 cam, RCD lifters and pushrods, RCD 120# valve springs, ARP 625s, o ringed heads, Warren 7mm 250/100 hybrids, Strictly bowl dereete regulated return, Air Dog 2 4g, Snow stage 2 water/meth
  #6
Old 07-12-2018, 06:15 AM
ToMang07's Avatar
General
Member's Gallery
Default
Yeah, I was reading up on those, seems you need to change the oil every 15-20k on them to be safe, they'll sludge up by 40k.
Even better is Ford lists it as a "non-service" item. I called to get an estimate on how much to have it done, (pump out ~2 qts and replace) they quoted me well over $300 after they told me it's a "lifetime fluid item and not usually done."
I laughed as I hung up.
__________________
  #7
Old 07-12-2018, 10:29 AM
Lieutenant
Member's Gallery
Default
Im sorry is the "ptu" a rear differential that has cv shafts like a vette or ton of other independent rear ends? Or is this just on the AWD versions?
__________________
  #8
Old 07-12-2018, 11:16 AM
79jasper's Avatar
Colonel
Member's Gallery
Default
Just awd. Basically a tcase.
__________________
  #9
Old 07-12-2018, 12:08 PM
ToMang07's Avatar
General
Member's Gallery
Default
^This. The weakest link on the SHO. Power Transfer Unit.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
